Ultrabay stubs and catches
Frotz
#1 Post by Frotz » Tue May 08, 2018 3:46 am
I've been looking all over for some replacement stubs and catches for an Ultrabay III. You can see these on the back and side of an Ultrabay III device. On optical drives, these always are screwed on. Does anyone here know what they're really called so I can order some from Lenovo? Or perhaps point me to where I can get some? Searching for "Ultrabay III" is association with "latch", "catch", "hook", and so on gives me lots of hits on replacing the latch inside the laptop, but nothing on these things that screw to the side of the device. Maybe you have some of them lying around doing nothing?
Re: Ultrabay stubs and catches
#2 Post by RealBlackStuff » Tue May 08, 2018 5:10 am
If you have one, can you take a picture and post the link to it here?
Hard to understand what you are talking about.
If it's the metal eyelet that stops the ultrabay unit from falling out, you can make those yourself from e.g. a tin can.
If it's the black plastic blob, no idea what that does, and if it's even needed.
turomini
#3 Post by turomini » Sun May 20, 2018 6:49 pm
I think this is the parts Frotz is talking about
(larger picture warming)
Back Stub: https://www.dropbox.com/s/7wsw5ap474hp4 ... 1.jpg?dl=0
Side catch: https://www.dropbox.com/s/zqykl5c7pcmm8 ... 7.jpg?dl=0
If so, I am not sure if lenovo sells these separately from a drive, they aren't listed in the HMM. Even if they did, I would think it is cheaper to just pick up a used cd/dvd drive with them already on, and just take them off. I think I say a few for under $10 on ebay.
Thinkpad4by3
#4 Post by Thinkpad4by3 » Sun May 20, 2018 11:17 pm
The back stub is to prevent the drive from going in a T4x machine. Snap it and you now have T4x compatibility.
Moderator
Moderator
#5 Post by dr_st » Mon May 21, 2018 2:43 am
Please stop spreading misinformation. (I really wonder how you are going to get "T4x compatibility" on a SATA optical drive). Not to mention the absolute lack of relevance, since the OP asked how to get the stubs, not what they are for. :)
Thinkpad 25 (20K7), X1 Carbon (20HQ), Yoga 14 (20FY), T430s (IPS FHD + Classic Keyboard), X220 4291-4BG, X61 7673-V2V
T60 2007-QPG, T42 2373-F7G, X32 (IPS Screen), A31p w/ Ultrabay Numpad, A21m 2628-GXU
#6 Post by RealBlackStuff » Mon May 21, 2018 7:12 am
Alternative to buying: if you're talking about the parts as shown above by turomini, find someone with a 3D printer, to copy them from an existing drive.
Users browsing this forum: sdfox7 and 13 guests
