Will trimmed 26R9246 Ultrabay adapter function in a T410s
Hi everyone:
I have a Thinkpad Ultrabay adapter model 26R9246. I bought it because I was told it would work in my T410s. However, it stops near the very end. I read that some people have got these Ultrabay adapters to fit into models for which they weren't designed by trimming off the plastic tab at the rear. Does anyone know if this will be compatible with a T410s? I'm handy with tools, so trimming off the plastic tab would be easy for me.
Re: Will trimmed 26R9246 Ultrabay adapter function in a T410s
No.
That adapter is meant for *60/61 series and has a PATA connector. It won't work in the T410/s no matter how you trim it.
Abused daily: T520, X200s
Colour me skeptical, as right on the drive bay it has the SATA logo, and reads "Serial ATA 1.5GB/s" . Also, I recognize the connectors as SATA, not parallel.
Maybe you're thinking of another model?
I should've been more precise in my previous post.
SATA logo refers to the type of drive used. Internal *60/61 architecture is PATA for the UltraBay. That changed in the 400/500 and later series.
No, I own that very adapter and use it in my T61p. Here's a ThinkWiki page on it as well:Maybe you're thinking of another model?
https://www.thinkwiki.org/wiki/Ultrabay ... DD_Adapter
This is the adapter that you need:
http://www.thinkwiki.org/wiki/ThinkPad_ ... dapter_III
You are 100% certain of this?
Does your T410s have a CD or DVD drive?
If yes, look at the connector at the back.
Then compare it to the connector on the 26R9246 Ultrabay adapter.
Rudeness was uncalled for. I simply asked for a confirmation. Lots of incorrect claims are made all over the Internet.
Your talking to the two top Thinkpad Forums users, both know just about everything about every Thinkpads and their owner just off the back of their hand. What you did was basically like asking Einstein "are you 100% sure about special relativity"
This ain't 4chan you know.
And yes he is correct. It has a built in SATA to PATA converter, and runs at IDE speeds.
Hahaha . Gotta hand it to you RBS, that was great!
When you first post on a forum, people's credentials aren't immediately visible under their nicknames, you know.Thinkpad4by3 wrote: ↑Fri Sep 14, 2018 8:49 amYour talking to the two top Thinkpad Forums users, both know just about everything about every Thinkpads and their owner just off the back of their hand. What you did was basically like asking Einstein "are you 100% sure about special relativity"
Funny, maybe, but also rude; I have to agree with the newbie here. Let's cut our new members some slack.
WTB: Ultrabay numeric keypad
by solidpro » Sat Nov 25, 2023 12:00 pm » in Marketplace - Forum Members only - 0 Replies
- 1394 Views
Last post by solidpro
Question regarding an mSATA-IDE Adapter for the X41
by Penguinboy829 » Mon Oct 23, 2023 6:25 am » in ThinkPad X20/X30/X40 Series incl. Tablets - 2 Replies
- 2496 Views
Last post by Penguinboy829
Wed Oct 25, 2023 5:44 am
Which models is W520's 170W AC adapter compatible with if keying removed?
by neilthinkpads » Fri Oct 27, 2023 12:25 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 4 Replies
- 3139 Views
Sat Oct 28, 2023 2:55 pm
Confused what NVME adapter is compatible with my Lenovo Thinkpad T480
by Cyber Akuma » Sat Dec 30, 2023 7:32 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 2161 Views
Sun Dec 31, 2023 1:17 am
