lf T400 SLIC2.1 or SLIC Marker tool
TPFanatic
#1 Post by TPFanatic » Tue Dec 25, 2018 4:16 pm
Anyone got a T400 modified bios with SLIC 2.1 or the SLIC marker tool for permanently adding the 2.1 table?
The original mydigitallife modded BIOS with SLIC 2.1 no longer exist, only no whitelist.
The modded BIOS from the wix site says it has SLIC 2.1 - it does not.
The baidu cloud link on 51nb to download the SLIC marker tool is dead.
Anyone have it to share?
Screamer
Re: lf T400 SLIC2.1 or SLIC Marker tool
#2 Post by Screamer » Wed Dec 26, 2018 6:32 am
I am not sure if this BIOS has SLIC 2.1 integrated, but it appears that it does have the SLIC 2.1 marker to manually add it in.
thinkpadcollection
#3 Post by thinkpadcollection » Wed Dec 26, 2018 11:47 am
T400/T500 needs both whitelist removal and slic 2.1 put on separately. I have done this same way years ago with a T500 now running Win 10pro when 10 came out for free in 2014. Still in use by my friend's but they will eventually replace this with newer one some day.
Cheers, thinkpadcollection
TPFanatic
#4 Post by TPFanatic » Wed Dec 26, 2018 8:39 pm
The SLIC marker worked. Very easy to use. Simply make bootable DOS with Rufus to a USB stick, copy the marker files, then boot DOS and run the .bat. My T400 activates the OEM Windows now. Thanks!
