To be clear up front, this question concerns my own Thinkpad, and doesn't involve forgotten passwords. I was trying to disable the supervisor password on the BIOS in preparation for passing the system onto a new owner, so I went into the BIOS, selected the option to change the supervisor password, entered the current password, and then hit enter three times, so the new password fields were both blank. I wasn't sure if this would work, but after hitting enter, the BIOS now said that the supervisor password was disabled. Satisfied, I exited the BIOS. I would assume I exited saving changes, but given what's happening now, I have to wonder if I exited without saving. I have no reason to expect that I'd do that, though.
Now, when I enter the BIOS, it prompts for a supervisor password, weirdly enough. If I enter the old password, it rejects it and displays an x. If I hit enter without entering the password, it accepts the password, but then the configuration menu acts as if I hadn't entered the supervisor password, and lets me change all of the settings except for the security related ones, which prevents me from cleaning up this mess.
I've updated the BIOS to the latest version (3.23), and I've tried changing settings and saving them, with the hope that that might trigger a code path that happens to fix this discrepancy, but neither of those actions has fixed the problem. Has anyone hit this problem before? If so, how did you end up fixing it?
Buggy BIOS confused by blank supervisor password
Re: Buggy BIOS confused by blank supervisor password
Usually bricked ThinkPads after failed BIOS update would require user to bring computer back to ThinkPad for motherboard replacement...
But here is a long shot (hope it works):
How to boot BIOS update from USB thumbstick (and not on hard drive, and not on DVD):
http://forums.lenovo.com/t5/Other-Linux ... -p/3743440
Hey, thanks for your reply. To clarify my original post, my T500 isn't bricked, and the problem is unrelated to the BIOS update. I updated the BIOS successfully (after hitting the problem, but before posting here), and the BIOS update didn't solve the problem.
Remove Supervisor password on x41
by LeoRgv » Thu Nov 09, 2023 3:08 am » in ThinkPad X20/X30/X40 Series incl. Tablets - 2 Replies
- 5006 Views
Last post by solidpro
Thu Nov 09, 2023 3:08 pm
X200 Supervisor Password
by pqq49 » Tue Mar 05, 2024 7:15 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 1 Replies
- 354 Views
Tue Mar 05, 2024 8:01 am
Confused what NVME adapter is compatible with my Lenovo Thinkpad T480
by Cyber Akuma » Sat Dec 30, 2023 7:32 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 2155 Views
Sun Dec 31, 2023 1:17 am
- 2 Replies
- 1029 Views
Tue Jan 23, 2024 3:23 am
Users browsing this forum: No registered users and 36 guests
