T520 lid latch broken in closed position; can't open
The left-side latch of the lid/screen is stuck in the locked position so the lid won't open. What can I do? The right-side latch is stuck in the unlocked position. The sliding switch won't move but if you lift up the right side of the lid 1/8" or so, so the hook isn't in the hole, you can slide the switch freely back and forth and it feels like there's no spring. Having taken apart the 520 many times to replace the keyboard and other things I can't imagine how even a repair shop could get into the left-side hole to unlatch it. I guess with some extremely fine stiff wire implement that has just the right U shape.
Re: T520 lid latch broken in closed position; can't open
Holy mackerel after an hour of panic and unsuccessful online searches and trying paper clips which are too thick and won't fit in the fine gap between lid and palm rest - I found an unusual variety of extra-fine mini-paper clip which was able to get into the left-side latch. If anyone knows about fixing the latch and switch let me know. Meanwhile I guess I'll open it up and look around.
Get the T520 manual from the HMM link at the top of each page.
Assuming you have the laptop open, remove charger and battery, then remove the LCD bezel.
You should now have full access to the latches, to clean/fix them.
Thinkpad X250 - Computer turns off when I open the lid after 10 seconds
by piggybackbandit » Mon Oct 16, 2023 12:35 am » in ThinkPad X230-X280 / X390 Series - 6 Replies
- 3355 Views
Last post by piggybackbandit
Tue Oct 17, 2023 1:49 am
[SOLVED] - Screen stays on when lid closed on Thinkpad W530
by MajedS » Thu Mar 07, 2024 12:45 pm » in ThinkPad W530/W540/W541/W550 Series - 2 Replies
- 331 Views
Last post by MajedS
Fri Mar 08, 2024 7:49 am
- 0 Replies
- 36 Views
Last post by simplify
Thu Mar 28, 2024 3:20 pm
Can anyone look at my pics and confirm if t480 lid is magnesium?
by redglow » Mon Dec 04, 2023 4:30 pm » in ThinkPad T430-T490 / T530-T590 Series - 4 Replies
- 2193 Views
Last post by mikemex
Sat Mar 02, 2024 2:57 am
Users browsing this forum: No registered users and 98 guests
