Bánh mì wrote:You are better off getting genunine Lenovo parts. Otherwise, its like driving a MBZ (fabrique aux Germany) and going into AutoZone and looking for parts.
As someone who does drive an older Mercedes and who does go to local, non-dealer parts stores and mechanics, I think that's a pretty good analogy.
Yes, you *could* buy everything from the dealer. That's an incredibly expensive way to do maintenance though, especially since the only difference between a great number of the "genuine" parts and the "generic ones" is the label. So too it is with laptops.
Here's what I'd recommend with regards to where to get your parts:
Batteries - Lenovo-branded unless you have a good source otherwise.
AC adapters - your call. Considering you can get Lenovo-branded ones for so little via the outlet, etc. third party ones don't make much sense.
Memory - skip the Lenovo-branded stuff. Memory is memory. It works or it doesn't. The Lenovo logo offers nothing other than a higher price-tag.
Planars - you don't have a choice. There are no generic ones.
Screens - depends on the model. Some models require specific Lenovo-only screens. Many don't. If you have one that doesn't, don't bother with Lenovo-branded screens -- get the unbranded (but identical) panels.
Plastics - generic unless you have reason to be suspicious. I've only ever seen one third-party plastic part that was *possibly* not identical (a T60 latch slider), and even then it worked perfectly, it just had slightly different seams.
Software - OEM stuff only (unless you like having your machine compromised from day one.)
Accessories - varies, but usually I'd say generic.
Really though, just use some common sense. If a part is dirt cheap, but from a reputable vendor... well... it's probably one of the many "fell off the back of a truck" "generic" parts. If it's dirt cheap, generic, and from some dude with a 85% feedback rating, I'd pass.
