W520 - Broken Trackpad Connector on Motherboard
Hey all! I picked up a non-working W520 for $15, thinking I could get parts. After I got home, discovered that after blowing out the fan, it worked great! Except for one thing ... The ribbon cable for the trackpad has a small connector with a tiny clip, located on the motherboard. That connector has completely broken off of the motherboard. I'm not talking about the clip breaking from the connector, as here: http://www.laptoprepair101.com/how-to-r ... therboard/, but the whole connector is snapped off and gone. Is there any hope for my trackpad? Any way to re-attach that cable to the mobo?
Re: W520 - Broken Trackpad Connector on Motherboard
Find a matching connector or (faulty) motherboard, use a rework-station and Bob's your uncle.
Otherwise you'll need to replace the motherboard, as it's highly unlikely that you can manually (re)solder such a connector.
Or, learn to live with the trackpoint and forget about a touchpad (and FPR) on that machine.
A lot of us don't give a hoot about a touchpad and disable it.
Bob's your uncle? Are you in AU??
Ok, if those are the choices, I think I'm going to have to live with the trackpoint, though it's *really* stiff. I mean, I could probably find a dead mobo someplace, but I haven't access to the proper soldering tools.
Thanks for your input!
More like IE, where my Auntie would be Siobhan.
X230T Keyboard trackpad button issue replacement?
by blink » Mon Nov 06, 2023 8:29 am » in ThinkPad X230-X280 / X390 Series - 3 Replies
- 2576 Views
Thu Nov 09, 2023 10:59 am
thinkpad t440p Linux trackpad + trackpoint not working.
by jaggreaney » Thu Nov 09, 2023 2:54 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 2795 Views
Thu Nov 09, 2023 11:48 pm
X1 Carbon replacement keyboard - stiff trackpad button
by Thinkpad2024 » Fri Mar 29, 2024 11:07 am » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 0 Replies
- 343 Views
Last post by Thinkpad2024
Fix a trackpad's left-click button on x230
by TOTAL » Fri Apr 05, 2024 7:33 am » in ThinkPad X230-X280 / X390 Series - 0 Replies
- 117 Views
Last post by TOTAL
