ThinkPad W500 Blu-ray drive
eMBe17
#1 Post by eMBe17 » Sat Nov 23, 2019 3:01 am
I'm looking for combo CD/DVD/Blu-ray drive, i guess it's called Serial Ultrabay Slim Blu-ray Burner. I looked for in many sites but it's hard to find. Maybe someone on this forum have one on sale ?
Regards
My collection:
ThinkPad 370C
ThinkPad 760XL
ThinkPad 701CS
ThinkPad 600X
ThinkPad W530
cadillacmike68
Re: ThinkPad W500 Blu-ray drive
#2 Post by cadillacmike68 » Wed May 20, 2020 2:57 pm
The only place I've seen more than one for sale is on ebay. Read the listings carefully and make sure it is a Serial Ultrabay Slim - NOT a Serial Ultrabay Enhanced drive. The enhanced drives are taller (12.5 vs 9.5mm) and won't fit. Otherwise the signals are the same. The Slim drive will fit in an Enhanced bay but not the other way around.
600 600X
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
wujstefan
#3 Post by wujstefan » Thu May 21, 2020 5:14 am
I should still have a couple of them.
(stable under reduction)
Commando303
#4 Post by Commando303 » Sun Jun 28, 2020 3:17 pm
Hello, I have one, but need to test it to make sure it remains properly functional (it's been a while since I used it; usually, I employ the Ultrabay to carry an additional hard-disk drive).
Please feel welcome to send a message to me.
Thanks.
emtee3511
#5 Post by emtee3511 » Fri Jan 29, 2021 4:48 pm
I know I am pulling up an old post, but I'm also looking for a Serial Ultrabay Slim blu ray drive for my W510.
:? I'm not even sure there is a blue ray for my machine.
emtee3511
X201 3680-AL6 + X200 7459-BW3 (Glossy)
+ X1 Carbon-Gen 6 20KH-002JUS + X1 Carbon-Gen 3 20BS-S22-A00
+ X1 Carbon-Gen 3 20BS-S22-A00 + X1 Carbon-Gen 3 20BS-S0Y-500
+ X1 Carbon-Gen 2 20A8-SOU-U00
+ W520-4276-37U + P51s 20JY-000AUS
TPFanatic
#6 Post by TPFanatic » Fri Jan 29, 2021 5:02 pm
For W510 with the thicker bay, the solution is easy. I bought an HP 12.7mm Blu ray drive and swapped over from a bad ThinkPad DVD drive the backplate, ultrabay lock, and faceplate. Voila, Blu ray in my T420.
theterminator93
#7 Post by theterminator93 » Sat Jan 30, 2021 11:47 am
There are factory Lenovo BD-RE drives for Serial Ultrabay Enhanced and Serial Ultrabay Slim. Serial Ultrabay Slim will physically and electrically work in the Serial Ultrabay Enhanced bays (there will be a gap) but it doesn't work the other way around.
Here are the part numbers:
45N7463 (-RE, Serial Ultrabay Enhanced - "thick" for T420, T430 etc.)
45N7459 (-RE, Serial Ultrabay Slim - "thin" for T400, T410 etc.)
Last edited by theterminator93 on Sun Jan 31, 2021 1:23 pm, edited 1 time in total.
T420 IPS FHD | X220 IPS FHD | T61p·T61·43·42p|X13 Yoga G3·220T·301·41T·24·23·22|G41|A31p·22m|i1200|TransNote
emtee3511
#8 Post by emtee3511 » Sat Jan 30, 2021 7:24 pm
Ok, so it looks like I'll make a trip to eBay. I'm afraid I would pick the wrong size "something" if I tried to go for a different brand. But it looks like I can use the slim or enhanced for ultrabay... so maybe I won't mess that up :?
emtee3511
