Whole row of dead keys
Weboh
#1 Post by Weboh » Fri Jan 29, 2021 10:35 pm
A whole row of keys just died on my W540: F2, F3, E, D, and C. All the keys worked fine until yesterday, when they all died at once. Anyone ever have this issue? Any ideas on how I can easily fix it? I don't want to replace the whole keyboard, but I do have one the same size from an E540 that I can put on there if I need to. Thanks.
kfzhu1229
Re: Whole row of dead keys
#2 Post by kfzhu1229 » Fri Jan 29, 2021 11:02 pm
This is very likely caused by a fault on one trace of the membrane or the keyboard connector itself.
First reseat the keyboard and clean the keyboard connector. If that doesn't work, then fixing might be very complicated and might involve with taking the entire keyboard apart and find the broken trace...
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
Weboh
#3 Post by Weboh » Sun Jan 31, 2021 10:11 pm
Thanks for the help. I tried cleaning the keyboard connector, but it didn't work. I don't have the electronics expertise to take the keyboard itself apart, but I realized I had my old E540 from the same year. Its keyboard was a drop-in replacement for the one on the W540. It doesn't have a backlight, but I never used it anyway.
Anyway, if someone wants the old keyboard, they can have it. You just need to have the expertise to find the broken trace.
