Dead W520 Display
Dead W520 Display
The LCD display of my W520 finally died today. I'd like to keep using it with an external monitor, but when I connect a display - either built-in VGA, docking station DVI or VGA - the external monitor stays dark. Is there a way to make the external the default display? Tried Fn+F7 without success. Thanks in advance.
Re: Dead W520 Display
Try setting it in the BIOS?
Thinkpads
R51 1829-W1C 2GB RAM
R500 2716-RY6
T520i 4239-47U
T530 2392-AQU 3610qm, 16GB RAM, classic kb
SK-8835 Ultranav keyboard Japanese layout
R500 2716-RY6
T520i 4239-47U
If you're running Windows 7 or later, try the Windows key + P combo
Are you sure you are looking at a dead display, or are you looking at no POST
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
Once Windows boots, by guessing when the password prompt appears, I can get into Windows and then the external display becomes active. Still will have to figure out what to do to get into BIOS to disable the built-in by default.
Google for: w520.swf and save it in a sub-directory.
Assuming you already uninstalled Adobe flashplayer, download this (working!) version: https://fpdownload.macromedia.com/pub/f ... _debug.exe and save it in the same sub-dir.
The above gives you the W520 BIOS-simulator.
Double-click the .exe (takes a while) and select w520.swf
Or right-click w520.swf and select: Open with that .exe
Write down exactly how to get blindly to: BIOS/Config/Display/Boot Display Device and switch that to Analog VGA, then go to Restart and select Exit Saving changes.
It's all Arrow-keys, Escape and Enter in 'real BIOS-live', so count properly!
Enjoy!
Enjoy!
@RealBlackStuff - Incredible, had no idea there was such a thing. Thank you!
Using the display and keyboard from a dead T460s?
by Gord K. » Sat Feb 10, 2024 12:10 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 467 Views
Sun Feb 11, 2024 6:32 am
- 5 Replies
- 358 Views
Last post by solidpro
Mon Mar 18, 2024 11:08 am
Which models is W520's 170W AC adapter compatible with if keying removed?
by neilthinkpads » Fri Oct 27, 2023 12:25 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 4 Replies
- 3148 Views
Sat Oct 28, 2023 2:55 pm
W520 w/ Mini Dock Plus Series 3 wattage error
by NoPyro » Tue Nov 28, 2023 4:34 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 7 Replies
- 2184 Views
Fri Dec 01, 2023 5:31 pm
