Hello
I spilled a small amount of sprite on the left side of my keyboard. I turned the laptop over, liquid dripped out. After about an hour, I turned off the computer.
After turning it back on, the keyboard didn't work. I took the keyboard out and dried it with a compressor. It still does not work.
Can I help her somehow?
In the commercial for thinkpads, they pour water on the keypads and everything is ok
thx
W540 - Flooded keyboard
My Thinkpads: T40, T43p, X60s, W510, W540
Re: W540 - Flooded keyboard
The keyboard took the fallout. The rest of the laptop is hopefully OK.
Soda is sugary. Commercials probably use distilled water, that's less likely to hurt anything....
P71 X330 T60 et al
Is it a good idea to rinse the keyboard with for example: alcohol or distilled water ??
NEW FHD IPS SCREEN FOR W540
by kiterunner » Fri Mar 29, 2024 3:37 am » in ThinkPad W530/W540/W541/W550 Series - 5 Replies
- 684 Views
Last post by kiterunner
Sat Apr 13, 2024 9:20 am
P1 5th gen - Swapping keyboard with WWan antenna for keyboard without Wwan. Possible?
by Phidelio » Mon Jan 15, 2024 9:21 am » in ThinkPad P1/P40/P50/P70 and later Series - 1 Replies
- 2241 Views
Last post by H-Atkinson
Fri Jan 19, 2024 2:56 pm
X230T Keyboard trackpad button issue replacement?
by blink » Mon Nov 06, 2023 8:29 am » in ThinkPad X230-X280 / X390 Series - 3 Replies
- 2668 Views
Thu Nov 09, 2023 10:59 am
- 3 Replies
- 1895 Views
Last post by Gonzaleitor
Tue Nov 28, 2023 4:19 pm
