I'm using a W520 running FreeBSD, that has also recently run Linux. But with both OS when you issue the shutdown -r now command it never finishes shutting down all the way no matter how long it sits and I have to do a hard reset by holding down the power button.
Then it may fire right back up when I turn it on, or I might have to do a hard reset many times before it starts the boot sequence.
Once it boots up it will run like it's supposed to. FreeBSD doesn't need rebooting as often as Linux so I have that installed now.
Please just say a prayer and let it be healed. Or advise me what to do.
W520 does not finish shutting down correctly
W520 running OpenBSD 6.2
T43 running OpenBSD 6.2
T61 running FreeBSD 11.1 x's 2
X61 running FreeBSD 11.1
T400 running Solaris 11.3
Re: W520 does not finish shutting down correctly
This actually sounds like a hardware issue. Due to its age (12 years by now), some of the electronic components (capacitors, resistors, etc.) may have degraded enough to go out-of-spec, resulting in unexpected behavior.
I've personally encountered a 2nd-gen Core i3 laptop (same vintage as the W520) that turns itself on again after completing a shutdown.
detachable battery does not charge. White light, then amber, then off.
by redglow » Wed Nov 01, 2023 6:12 pm » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 10213 Views
Last post by redglow
Fri Nov 03, 2023 2:05 am
WorkPad Z50 strip down and clean up [WARNING: PICS]
by ThinkDan » Fri Feb 02, 2024 5:56 pm » in ThinkPad Legacy Hardware - 3 Replies
- 894 Views
Last post by ThinkDan
Sun Mar 10, 2024 6:54 pm
W520 w/ Mini Dock Plus Series 3 wattage error
by NoPyro » Tue Nov 28, 2023 4:34 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 7 Replies
- 2275 Views
Fri Dec 01, 2023 5:31 pm
2 questions, RAM upgrade and OS downgrade on a W520
by NoPyro » Sat Dec 02, 2023 1:55 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 9 Replies
- 7522 Views
Last post by mikemex
Thu Feb 22, 2024 1:47 am
