A21 Turns on then off inmediatly
Hey guys, i've bought recently a thinkpad A21, the matter with it is, i plug the charger and when i turn it on "in matter of seconds" turns on the leds, the hdd spins then it turn off, i've tried as i read in the forum, removing the hdd, the dvd drive, battery etc, the only time when it stays on without any problem is when i remove the ram (2 modules, 128mb & 256 mb), then i get the following beeps: 3-3-1 (not 1-3-3-1 as i've seen on the forum), i've checked the board if everything was in order, the processor got new thermal paste, etc, i wonder what should be happening whit this, thats i why i ask here to get any clue about, thanks in advance for any reply given
Btw i left it pluged in all the night, the battery has not charged, and the amber led (battery one) keeps flashing.
Last edited by dvdmcwilliams on Tue Mar 27, 2018 10:27 am, edited 1 time in total.
Re: T21 Turns on then off inmediatly
T21 in title
A21 in post
Which one is it?
If the battery light remains flashing, it means the battery is dead.
A21 in post
Which one is it?
Sorry, my mistake about the title, i've removed the battery, but wont even turn on.
Re: A21 Turns on then off inmediatly
Disconnect both charger and battery, keep battery out from now on.
Remove all RAM.
Press and hold down the Power button for 20 seconds (to reset the laptop).
Connect only charger.
Put only 128MB in one slot, then try to boot.
If no luck remove charger, put 128MB in other slot, connect charger and try again.
If no luck remove charger, remove 128MB, put only 256MB in one slot, connect charger and try again.
If no luck remove charger, put 256MB in other slot, connect charger and try again.
If still no luck, check if someone else has a similar machine to try your RAM in.
Or try their RAM in yours.
Most likely however the motherboard is dead, don't forget it's almost 18 years old...
Remove all RAM.
If all else fails, something to keep in mind is many of the 20 series (A2x, T2x, X2x and TransNote) have a fairly well known motherboard design flaw around the implementation of the power circuit. There isn't a fix that I know of, aside from a known working motherboard. Some have suggested the source problem as the ADP3410, ADP3421, and/or MAX1632 voltage regulation ICs, but I've seen plenty of instances where replacement did nothing, and a few where replacement fixed the issue...
T420 IPS FHD | X220 IPS FHD | T61p·T61·43·42p|X13 Yoga G3·220T·301·41T·24·23·22|G41|A31p·22m|i1200|TransNote
Could it be a cmos battery the problem? or doesnt matter if its connected?
Edit: i've tried what you said, i've removed the ram, then i used just one, after press the power button for more than 20 seconds, it turned on, but blank screen, no sound, no beeps, etc. i've connected a monitor but it get no signal.
Does the T30 and A31 series have the same problem? All the A31p motherboards I have touched have more or less of this issue, ranging from sometimes requiring to attempt powering on twice to complete death and does not charge the battery properly. That said, I haven't noticed this issue on my T22, T23 and A30/p motherboards.theterminator93 wrote: ↑Tue Mar 27, 2018 11:16 amIf all else fails, something to keep in mind is many of the 20 series (A2x, T2x, X2x and TransNote) have a fairly well known motherboard design flaw around the implementation of the power circuit.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
That I can't say, as I don't own either model I haven't done nearly as much research about this issue on them. But I can't say it's not possible. I'd say it's more likely on the A30 than the T30 because the T30 uses the Pentium 4, whereas all the 20 series and the A30 used one of the Pentium III flavors - meaning they're more likely to be similar in architecture overall than the T30.
This issue intermittently affects one of the A22ms and my TransNote (which is essentially a reworked X20 motherboard)...
I am almost completely sure that Tualatin Pentium III CPU laptops are mostly unaffected, because their TDPs are a LOT lower than both Coppermine and Northwood, and the P4-M has a lower TDP than Coppermine PIII. This means that the power delivery circuits get stressed a lot less.theterminator93 wrote: ↑Tue Mar 27, 2018 2:31 pmThat I can't say, as I don't own either model I haven't done nearly as much research about this issue on them. But I can't say it's not possible. I'd say it's more likely on the A30 than the T30 because the T30 uses the Pentium 4, whereas all the 20 series and the A30 used one of the Pentium III flavors - meaning they're more likely to be similar in architecture overall than the T30.
I own a T23 and A30p, both work very reliably, even after some pretty moderate use as a music player on my A30p (that is, with the GPU protected from overheating).
While, my Pentium 4 A31p currently is affected by the RAM slot problem as well as that issue with power-on fails intermittently (sometimes turns on with no motors spinning).
UXGA:
UXGA:
No.
The problem described in the OP is one of the variations of BOD (Blink Of Death) which has been known to affect *all* A2x systems along with T20/21/22 but not T23 or any of the later models.
Abused daily: T520, X200s
detachable battery does not charge. White light, then amber, then off.
by redglow » Wed Nov 01, 2023 6:12 pm » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 9862 Views
Last post by redglow
Fri Nov 03, 2023 2:05 am
[RESOLVED: CPU had died!]: ThinkPad L540 froze then rebooted and now black screen
by glossywhite » Sun Dec 10, 2023 2:17 pm » in ThinkPad L430/L530 and later Series - 20 Replies
- 10119 Views
Last post by glossywhite
Wed Dec 20, 2023 7:02 pm
P14s Losing Power When OFF
by tenplus1 » Sat Dec 16, 2023 5:22 am » in ThinkPad P1/P40/P50/P70 and later Series - 7 Replies
- 1942 Views
Last post by tenplus1
Fri Jan 05, 2024 6:42 am
