ThinkPad Z60m as a portable desktop
R, A, G and Z series specific matters only. NOT for AMD-Ryzen.
sestulak
#1 Post by sestulak » Thu Apr 26, 2018 2:12 pm
So I was thinking about buying an old Z60m withouth working screen, my question is - is it possible to remove the screen and use only the keyboard part with motherboard and connect it to an external screen via VGA if not is there any model that can do that?
Re: ThinkPad Z60m as a portable desktop
#2 Post by RealBlackStuff » Thu Apr 26, 2018 4:58 pm
Yes, all Thinkpads can do that.
TPFanatic
#3 Post by TPFanatic » Thu Apr 26, 2018 5:56 pm
It won't be very fast, mind you, with its Pentium M and very dated ATI graphics at best.
lenovo X230 i5 3320m IPS 8GB
lenovo T430 i5 3320m FHD 8GB
lenovo T430s i5 3230m QHD 8GB
lenovo T500 P9700 WUXGA 8GB
Enable 2 finger scroll on any Synaptics touchpads with registry: http://forum.thinkpads.com/viewtopic.php?f=2&t=122612
sestulak
#4 Post by sestulak » Thu Apr 26, 2018 11:01 pm
Even when running some Linux distro?
TPFanatic
#5 Post by TPFanatic » Thu Apr 26, 2018 11:11 pm
Depends on what you're doing. If browsing, Firefox 32 bit is very slow nowadays. You can play some retro games though if you have ATI GPU.
richramo
#6 Post by richramo » Tue May 22, 2018 6:44 pm
My 2 cents worth,
Found that Point Linux works really well on old Thinkpads with M processors. (T42s etc)
Thinkpads
X61s - C2D L7500 1.60Ghz, 2G, 100GB | X31 - PM 1.4Ghz, 1G, 40GB | T40 - PM 1.5Ghz, 512MB, 40GB | R40 (the beast) - PM 1.4Ghz, 256MB, 20GB | 390X - P Celeron 400Mhz, 96MB, 6.4, | 755c (Golden oldy) - 486DX7 75Mhz, 20mb, 510mb - Still works :) | 730TE Tablet
Thedarkb
#7 Post by Thedarkb » Sat May 26, 2018 8:24 am
You'll be able to do basic tasks without issue running Lubuntu or Debian but web browsing may be a bit slow.
Wanted: 14" T60 SXGA+ panel
For sale: Z60m
