Thinkpad r40 processor upgrade?
Is it possible or is it soldered
Re: Thinkpad r40 processor upgrade?
Also if this has been posted already I'm sorry just direct me there as I am new to forums in general
I think it is upgradable
This Hardware Maintenance Manual shows a socketed CPU: http://tim.id.au/laptops/lenovo/thinkpad%20r40.pdf
But there must be someone around here who's actually had one of these and knows.
Home: L440 | R500 | X120e Server
Work: ThinkPad Yoga 260 | Dell Latitude 5320
It is possible...however...
R40 came in two different guises: with P4M CPUs and PM Banias ones. These are not interchangeable.
If you could post the 7-character model number found on the sticker on the bottom of the laptop (which also holds the serial number and the production date) I could give you a more precise recommendation.
Abused daily: T520, X200s
You can upgrade the R40 with either a Pentium-4 or a Celeron CPU, depending on motherboard.
(Read the R40 manual as well).
Unless you have nothing better to do, I wouldn't waste any money on an R40.
It is not even an IBM machine, but just some rebadged POS made by Acer.
I wanna get the r40 to the best it can be because it was my first computer. I'm running linux on mine. Linux rules. As for the processor it's a pentium 4 m 2.0 ghz
I'd leave that "as-is", for the following reasons:
1) While the P4M 2.2, 2.4, 2.5 and 2.6 will work, the difference in performance will be minimal by today's standard yet the machine will run significantly hotter. There is no upgrade path for the cooling system on R40.
2) I've owned a 2.4 version - the fastest factory option - and even in a 15" frame it was hideously hot when pushed. This was in XP, I don't even want to imagine how it would be under Linux which tends to run hotter in my experience.
3) Top 2.5 and 2.6 CPUs are still incredibly expensive nowadays.
Unlike most people on this forum I have a soft spot for R40 and have played a lot with them. But apart from maxing out the RAM if you haven't done so already and getting a newer hard drive I'd leave the system alone.
Can you link me to a battery for the r40 main battery and expansion bay battery. Please?
Also im running peppermint OS a very lite version of linux mint
Also how do I make a signature? I'm on my phone.
ajkula66 wrote: ↑Sun Feb 14, 2021 2:26 amI'd leave that "as-is", for the following reasons:
Like how much for a 2.6?
Daaaaaaaaaang. Gonna have to call my rep payee :O dey controls da moolah
I got both now, haven't bought yethannahhatesherself wrote: ↑Sun Feb 14, 2021 4:15 amCan you link me to a battery for the r40 main battery and expansion bay battery. Please?
Likely close to $100 if you can find one. Look for SL6WZ.
2.5 is SL6WY
2.4 is SL6VC and these seem to be priced around $20 which is not all that horrible.
I'm going 2.6. gotta have the best for Emily. I have to install win 98 se to update bios (plus the hdd had my cringey 13 year old minecraft let's plays).what's an iba slot?
Good luck.
You're much better off burning an image and updating the BIOS from the media drive instead of doing it through Windows IME.I have to install win 98 se to update bios
"the diskette in the default drive will not run on this system. Your system is now locked. To restart your system press ctrl+alt+del."
What's causing this error
Wrong BIOS version ?hannahhatesherself wrote: ↑Sun Feb 14, 2021 2:05 pm"the diskette in the default drive will not run on this system. Your system is now locked. To restart your system press ctrl+alt+del."
What happened prior to this prompt ?
Installed 98se on spare hdd, burned a disk with updater on w10 (I hate it but tis a necessary evil) ran it , computer started install then errored
Did you do this using the R40 ? With the new drive in the main bay ?
Yes I did. Then I read the controller thingy and saw that it had to be updated first so I did that but it was already updated
Sorry I haven't touched 98SE in well over a decade, can't really offer any useful advice.
Good luck.
Good luck.
2.6 WILL fry the system in the long term. Those chips produce so much more heat that Intel had to put more TDP rating in them, which is something they usually don't do (in Pentium III-M for example) to give you an impression that the faster chips are truly better in every single way.hannahhatesherself wrote: ↑Sun Feb 14, 2021 12:06 pmI'm going 2.6. gotta have the best for Emily. I have to install win 98 se to update bios (plus the hdd had my cringey 13 year old minecraft let's plays).what's an iba slot?
I have the 2.5Ghz SL6VC part and that's already exhibiting quite significantly more heat than a 2.2Ghz part. My 2.5Ghz CPU came out of a A31p motherboard with its VRM thoroughly cooked thanks to the 2.5Ghz part.
I don't have confidence that the motherboard on the R40 would have good enough power delivery to sustain a 2.6Ghz CPU in the long run. Heck it might not even have a good enough chipset to make full use of it.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
ThinkPad 701C with AMD upgrade on ebay
by ThinkDan » Mon Dec 04, 2023 10:01 am » in Marketplace - Forum Members only - 1 Replies
- 1447 Views
Last post by H-Atkinson
Thu Dec 07, 2023 10:33 pm
Thinkpad 770 Bios mod for cpu upgrade
by franjimo24 » Sun Dec 10, 2023 8:14 am » in ThinkPad Legacy Hardware - 6 Replies
- 4997 Views
Last post by solidpro
Tue Jan 23, 2024 4:02 pm
t400 lcd mod/upgrade possible?
by astral » Sun Oct 01, 2023 5:36 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 6 Replies
- 3299 Views
Last post by astral
Mon Oct 02, 2023 9:22 am
Couple issues with Lenovo E530 after upgrade
by topperdude » Sat Oct 14, 2023 8:40 pm » in ThinkPad Edge / E-series - 3 Replies
- 3721 Views
Sun Oct 15, 2023 11:50 pm
Users browsing this forum: No registered users and 44 guests
