R50 CPU/GFX heatsink?
solidpro
#1 Post by solidpro » Sun Sep 25, 2022 11:11 am
Hi All
I'm at my wits end. I Had an R50e which I thought was just a smashed screen - so I replaced the screen only to find out the motherboard is a goner. So I spent £30 on an R50 motherboard and then discovered the R50 has a much larger heatsink covering what I think is the northbridge and the ATI chip below it has a silver coloured metal heatsink on it (not powered). So I thought I had all the bits but it powers down after a few seconds, and realised the northbridge gets super hot and is probably shutting down for protection.
Now I find the Heatsink for the R50 is on ebay but only in Germany and USA and the combined cost of getting it is about £60 which is waaaaay more than this machine is worth and now I'm worried even if I get it, there will be another problem and the R series machines are ones I really don't care about much anyway, so i'm now chasing a sunk cost fallacy. A frustrating dilemma. Anyone got any ideas on what I should do? I think finding a cheaper heatsink on ebay will take forever and in the meantime this thing has to sit around in pieces for months....
WANTED: 130, 220, 300 ,240Z, 235, 300C, 310x, 315D, 320, 330x, 345x, 350x, 355x, 360x, 365x, 385x, 390X,
ANY 5xx Series, 700, 700C, 701CS, 720, 720C, 730TE, 750, 750C, 750P, 755x, 760x, 765x, 770x
ANY 8xx Series, A20P, A21p, A22p, A30p, A31p, R30, R50, R50p, R52, T40p, X2x, X3x, X40
