Weird Search Problem
Recently I upgraded from Windows Vista to Windows 7, doing a clean install, and copying document folders from backups to the desktop. I was able to use search from the start menu, and find any of my documents normally. Then, suddenly, some documents that I was able to find only two days ago do not come up in a search. Parenthetically, I looked in the recycle bin to make sure that the missing documents had not inadvertently been deleted. They had not.
I did a rebuild of the indexing, and still no success. The only thing that I did in the interim, if memory serves correctly, was install OpenOffice 5.4.0. One other thing worth mentioning is that in some places online it is recommended to run the LibreOffice installer as administrator (the same is recommended for OpenOffice). I might have done so had right-click run as administrator been an option, but it was not as is sometimes occurring with msi installer packages
There is an automatic registry fix which would have added that option, and another complementary fix to remove the option from registry. I ran that by my local technician, but he insisted that LibreOffice did not need to be installed as administrator.
One other thing. In the indexing menu it shows that the local C Drive is included in indexing. Does this mean that the desktop is included as well?
I would appreciate any help/
Re: Weird Search Problem
After using them, LibreOffice might have renamed those files to .ODT or something.
Thanks for the response, RBS.
LibreOffice by default saves to ODF, and when I checked in the indexing options, ODF was included.
One of the files that doesn't show up was a notepad file (TXT), and other notepad files show up just fine when I search.
Often, in the past, I would search by a keyword in a file, rather than by the file's name, and there was no problem. It worked the same way in Windows 7 until a couple of days ago.
I did a search online, and found out that there have been a number of people who have experienced the same problem with Windows 7… missing files, missing folders, etc. in many cases Microsoft suggests rebuilding the indexing, which I've done twice with no effect. There is also a hot fix that is available upon submitting an email request to Microsoft.
Since I posted a few more files went missing. Doing some more research, I went into Windows Explorer, clicked on C: Drive, then Users, then Main User. There, under My Documents I found the more recently "disappeared" files, but not the earlier missing file that prompted this inquiry. The point is that even though these files are clearly on my computer, searching does not bring them up. Any ideas?
I had a similar sounding problem several years ago when I first got my Win7 x64 T410. After weeks of troubleshooting, it turned out to be a conflict with my antivirus software. If I remember correctly (5+ years ago) just turning off my a/v didn't help. I had to actually uninstall it to prove it was the problem. I ended up switching a/v products.
Just my 2 cents, for what it's worth.
Here are some very old topics:
https://community.mcafee.com/thread/274 ... 0&tstart=0
https://forum.bitdefender.com/index.php ... nder-2011/
Gary A.
lenovo: T490 (20N20028US) | i7-8565U | 16GB | 512GB SSD | FHD LED | WiFi 9560 | Bluetooth | Webcam | Win10 Pro x64 | Full System Specs
Or you can purchase a search program such as X1
www.x1.com
Been using this for many years; saves you a lot of time in locating your files!
(No, we do not work for X1 !)
www.x1.com
Why pay for such a program (X1 Client), and get slapped with a service fee, when you can get a better one (Lookeen) for free?
X1 vs Lookeen: https://lookeen.com/solutions/alternati ... ative.html
Free download: https://free.lookeen.com/download.html
(I do not work for Lookeen)
My dad's laptop had an issue with his computer constantly loading up a temporary user and it wouldn't have access to his original user files.
It loaded up with his name and stuff, but sometimes his original background wouldn't load up.
This would happen intermittently, it was most problematic whenever he had scanned a document and it wouldn't show up...
Not sure if this is what you are encountering, but it could be. link
Coffee, ThinkPads & Nikon Fan.
Current: PixelBook & Precision 7730
Old Favorites: A31p, T43p, T430s
Strange T480 Shift lock problem.
by unified11 » Mon Feb 05, 2024 7:17 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 438 Views
Last post by ZaZ
Mon Feb 05, 2024 10:52 pm
How bad was the Thunderbolt Firmware Problem
by euless » Wed Feb 07, 2024 4:19 am » in ThinkPad T430-T490 / T530-T590 Series - 3 Replies
- 836 Views
Last post by TPFanatic
Sun Feb 11, 2024 6:20 am
X1 Carbon Gen 9 - crackling problem
by vmd108 » Tue Mar 05, 2024 5:27 am » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 1 Replies
- 380 Views
Last post by mikemex
Wed Apr 03, 2024 2:00 am
- 11 Replies
- 1233 Views
Last post by Ken Edmonds
Fri Mar 29, 2024 11:39 am
