Wi-Fi Broken after downloading updates.
I'm working on an Acer Aspire system for a client and have reloaded the O/S without a hitch...until I downloaded 119 Important (not the optional) updates and then rebooted the system.
After rebooting the system I found that the Wi-Fi would no longer work. "No Networks Available" I believe was the message in the connection box when you click on the icon in the tray. Even hardwired it would not connect to my router.
So I deleted and re-installed the Atheros drivers for the card and re-installed and still nothing. The Device Manager said there were no drivers installed for this device which I found strange since it was working with these drivers before the updates were installed and I had in fact just re-installed the driver.
Instead of going through 119 updates and deleting each one to see if I could isolate the update I just reloaded the O/S once again. After installing the wi-fi driver everything is back the way it should be and is working correctly...without those 119 updates. I did install a couple of .NET updates and Malicious Software Removal update but wi-fi was not affected.
Now, I could find nothing on the internet about any updates breaking the wi-fi on Windows 7, but plenty of complaints about one update or the other breaking the wi-fi in Windows 10. Apples and oranges.
Does anyone know which KB # could be breaking the wi-fi on this system? Almost all of the updates were 'security' related as MS likes to call them but who knows what else is rolled up in all of that crap.
A31p P-IV 2Ghz, 2MB, 2653-R6U
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T16 i7 1260P 21BV000SUS
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
Re: Wi-Fi Broken after downloading updates.
I found two updates for Win 7 that are screwing up wi-fi connections.
It was very early this morning when I was searching for this (0130 local) so I'm sure I either missed it or wasn't using the correct search terms.
They are KB4088875 and KB4088878.
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
After checking for downloads out of the 118 (and 62 optional), those two KB updates do not appear in the list of updates available for download.
Now I'm right back where I started. Still don"t know which update breaks the wi-fi.
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
Was a new driver among the updates?
No, there were no equipment updates for Acer or components in any of those updates. Further, the driver was identical both before and after the updates.
I guess I will end up installing these updates in batches of five and reboot after each batch until I find the update that causes this problem. I have since downloaded and installed the Service Pack 1 update and the computer still connects normally.
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
Earlier this year on Windows 7 some hardware was causing WIFI issues after updates and "KB4099950" was put out as a fix.
Might be worth a try if you haven't already.
Active --- Love the X series
X301 W 7/Mint | X201 540M L Mint | X220 2520 W7/Mint
Nostalgia
X61 T7500 / T41 T42 T43 / A31
Nostalgia
W530 Bluetooth sound broken after switching to windows 10
by Gregui To » Sat Dec 09, 2023 6:17 pm » in ThinkPad W530/W540/W541/W550 Series - 1 Replies
- 2582 Views
Last post by mikemex
Wed Feb 21, 2024 12:42 am
Broken T60/61/400/500 keyboards - free
by Glaurung-quena » Tue May 07, 2024 8:31 am » in Marketplace - Forum Members only - 2 Replies
- 175 Views
Last post by Glaurung-quena
Wed May 08, 2024 3:55 pm
ThinkPad T460 refuses to stay on after power button is pressed
by Fropple! » Fri Dec 08, 2023 1:31 am » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 8509 Views
Last post by Fropple!
ThinkPad A22m battery recondioning after battery rebuild
by kfzhu1229 » Mon Dec 11, 2023 5:57 pm » in ThinkPad R, A, G and Z Series - 0 Replies
- 2652 Views
