Strange error (almost) disables my fresh Win7 installation.
Hi.
I have been fixing up an X220 in the last couple of days, but now that I am installing Win7 I have encountered a new problem that I haven't seen before; Whenever I try to do anything I am met with an error message that says 'A certificate chain processed, but terminated in a root certificate not trusted by the trust provider'. I can't surf the web, and most of the programs I want to install including .NET 4.8 and by extension anything that relies on it gets denied. I tried running Windows Update but it times out (Error 8024001F), and manually installing the update that I think is supposed to fix the issue does nothing.
Have any of you guys encountered this issue? For the record I am installing Win7 Pro from the .ISO that Microsoft currently has available for download on their webpage, which is version 6.1 build 7601.
Re: Strange error (almost) disables my fresh Win7 installation.
Sounds to me like the unpatched RTM ISO uses the now expired Let's Encrypt certificate.
https://www.zdnet.com/article/fortinet- ... t-expires/
Possible resolution here: https://community.letsencrypt.org/t/fix ... s/161162/3
T420 IPS FHD | X220 IPS FHD | T61p·T61·43·42p|X13 Yoga G3·220T·301·41T·24·23·22|G41|A31p·22m|i1200|TransNote
Oh yes. Root certificate expiration was a headache some time ago.
If you have such issues with W7 -which is not particularly dependent on external things- I can't imagine the nightmare W10 is going to be when it goes offline. Half of the parametric / dynamic UI is going to vanish.
X1C5: 7600U | 16GB | 1TB | FHD
X1C9: 1145G7 | 16GB | 1TB | WUXGA | WWAN
P14s G1 AMD: 4750U | 32GB | 1TB | PG FHD Touch
T14 G2: 1145G7 | 32GB | 1TB | FHD
Check this out: viewtopic.php?f=11&t=128170
It includes W7-Pro for X220.
I solved it!
Updates KB4474419 and KB4490628 from the Microsoft Update Catalog (https://www.catalog.update.microsoft.com/Home.aspx) enabled Win7SP1 Pro to utilize the SHA-2 certificate, which in turn allowed me to install .Net 4.8 and Lenovo System Update. At the time I am writing this, Lenovo System Update is temporarily unavailable, but that will probably get resolved sometime soon without me having to do anything.
I sure hope that they make similar updates available for Win10 when it reaches its EOL and some update breaks compatibility, but I am not holding my breath!
That will depend on the active user base at that time. Given the current user base, I think chances are good.Garlic Bread wrote: ↑Mon Oct 11, 2021 5:24 pmI sure hope that they make similar updates available for Win10 when it reaches its EOL and some update breaks compatibility, but I am not holding my breath
Both of the updates you mentioned are from 2019, before Win7 EOL, BTW.
Strange T480 Shift lock problem.
by unified11 » Mon Feb 05, 2024 7:17 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 438 Views
Last post by ZaZ
Mon Feb 05, 2024 10:52 pm
- 0 Replies
- 206 Views
Last post by Swonco
Thu Mar 21, 2024 12:03 pm
- 1 Replies
- 1601 Views
Last post by SMA
Mon Oct 23, 2023 9:27 am
- 0 Replies
- 2014 Views
Last post by dvmopar
Tue Nov 14, 2023 8:34 pm
