Ok, I want to paint my Thinkpad after seeing this.
Now this is what I call painting a Thinkpad: http://www.trevorshp.com/creations/laptop.htm
Or when you install Linux on your R40e: http://www.craigsarea.com/paint_laptop.html
Or put David Hill( ) on the back cover: http://www.instructables.com/id/Painting-a-laptop/
I wonder if that would be a good idea for some lids that are more heavily scratched to hide the scratches?
Seems like a good idea on the commoners like those 4x machines. Wouldn't dare to put a drop of paint on the rare birds.
Re: Ok, I want to paint my Thinkpad after seeing this.
I couldn't bring myself to deface my poor ThinkPad like that...
Maybe a vinyl graphic instead. At least you won't feel so bad about it, eh.
| 701c | X220 | T420 | X230 | T430s | W540
I wouldn't mind it if it was scratched up a bit. If it was mint, or even close to mint, forget about it. I don't think the vinyl graphic would hold much better because the glue would make it all sticky
Since my X220's battered and beaten, I'm wondering if powdercoating is a viable option for the magnesium lid and bottom chassis.
Powder-coat a design or just a flat color? What color/design are you thinking of.axur-delmeria wrote: ↑Fri Jul 21, 2017 12:30 pmSince my X220's battered and beaten, I'm wondering if powdercoating is a viable option for the magnesium lid and bottom chassis.
Bog standard ABS is easy to coat but remove the rubberised coating and then wipe with a solution 50% IPA 50% demin with a lintfree cloth to remove any static. Any automotive plastic primer will fill any scratches in - just don't leave anything that doesn't like heat in the lid when you cure the paint.
You would have to remove all the guts just leaving the lid n base due to the electrostatic powdercoat process.axur-delmeria wrote: ↑Fri Jul 21, 2017 12:30 pmSince my X220's battered and beaten, I'm wondering if powdercoating is a viable option for the magnesium lid and bottom chassis.
Home - Win 10 MSi GF63 Gaming Laptop /Arch GNOME 3/X230 Tablet /X61 [Korean] - Debian 10/T60p - Ubuntu 20.10 Helix 2
Work - Win10/Thinkpad X1 Tablet Gen 2
Flat black, as a Thinkpad should be.Thinkpad4by3 wrote: ↑Fri Jul 21, 2017 12:51 pmPowder-coat a design or just a flat color? What color/design are you thinking of.
My aunt's X60 is even more battered-- the cat had a habit of sleeping on top of it. The lid is full of little scratches as a result.
I wonder.... could that FlexSeal stuff that is on TV could be a substitute for a rubber finish. It is rubber(??) after all. Just bondo the cover, then FlexSeal. When you are done, you can patch up your car and fix that leaking windowaxur-delmeria wrote: ↑Fri Jul 21, 2017 9:40 pmFlat black, as a Thinkpad should be.
Dunno if FlexSeal isThinkpad4by3 wrote: ↑Fri Jul 21, 2017 9:50 pmI wonder.... could that FlexSeal stuff that is on TV could be a substitute for a rubber finish. It is rubber(??) after all.
1. available in my country
2. won't flake or run. Roofs, walls, and pipes just sit there and you don't really touch/handle them every day. Laptops on the other hand, are held, grabbed, stuffed into bags, and suffer all sorts of physical contact (or abuse for that matter).
Maybe you could test it on a Thinkpad carcass first?
Another crazy idea is "bare metal" (all paint removed/sanded down) so the magnesium is exposed, then apply a few layers of scratch-resistant, matte clear coat. :O
One problem with bare metal look, It might look like a MacBook????????
Put an IBM badge from a Z61 (titanium lid) so they know its not a mac
What's the best way to remove paint from stock Thinkpad coolers?
by cultOfThinkpad » Sun Dec 10, 2023 6:52 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 1 Replies
- 4408 Views
Sun Dec 10, 2023 12:55 pm
ThinkPad T460 refuses to stay on after power button is pressed
by Fropple! » Fri Dec 08, 2023 1:31 am » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 7527 Views
Last post by Fropple!
ThinkPad A22m battery recondioning after battery rebuild
by kfzhu1229 » Mon Dec 11, 2023 5:57 pm » in ThinkPad R, A, G and Z Series - 0 Replies
- 2475 Views
W530 Bluetooth sound broken after switching to windows 10
by Gregui To » Sat Dec 09, 2023 6:17 pm » in ThinkPad W530/W540/W541/W550 Series - 1 Replies
- 2252 Views
Last post by mikemex
Wed Feb 21, 2024 12:42 am
