Thinkpad 755 HDD reformat/factory reset
I lost Windows password, is there a way to factory reset 755 or reformat HDD from DOS?
Was not able to find anything on Google.
Please advise.
Thank you!
Please advise.
Thank you!
Re: Thinkpad 755 HDD reformat/factory reset
You can reformat, as long as you have a floppy drive and disks.
I do have some floppy disks I can use, is there a step by step procedure?
Thanks.
Thanks.
Is there a step by step procedure?
- **SENIOR** Member
Boot from the floppy, then enter:
format c:
I think it should be:
right?
But before that, you should make a bootable floppy. Whether it's MS-DOS 6.22, FreeDOS, IBM PC-DOS 7, DR DOS 7.1, or whatever, get a floppy disk image (usually with .IMG extension) or installer EXE file. I haven't created a DOS disk in years, but the last time I did, I used an old Windows program called WinImage to create a boot disk from IMG files.
If you want Windows though, that's another matter entirely.
format c: /s
- **SENIOR** Member
Yes! Absolutely right. It's been a whie since I did this...axur-delmeria wrote: ↑Fri Oct 20, 2023 8:58 amI think it should be:
right?Code: Select all
format c: /s
ThinkPad from the 755 era with transparent screen
by Int_31h » Mon Feb 26, 2024 9:03 am » in ThinkPad Legacy Hardware - 17 Replies
- 1338 Views
Last post by BillMorrow
Tue Mar 19, 2024 12:51 pm
- 0 Replies
- 346 Views
Last post by Half-Saint
Wed Mar 06, 2024 4:36 am
Issues with restoring original factory software to a t42
by Glaurung-quena » Thu Feb 08, 2024 7:37 pm » in ThinkPad T40/T41/T42/T43 Series - 10 Replies
- 1880 Views
Last post by micrex22
Wed May 01, 2024 6:49 pm
Is it possible to recover T400 factory setups of Win XP or 7?
by PhoenixR » Fri May 17, 2024 3:25 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 0 Replies
- 275 Views
Last post by PhoenixR
