Best classic traveling companion?
My research indicates that 240Z or 570E might the best ones. Performance is not a concern, battery life is more important.
Issues are:
I'm using my X61s as reference.
I assume both are quite rare. (expensive?)
I know nothing about the battery life.
Quality panels? Both have UXGA, TN for 240Z and E-INK(?) for 570E. (Look for them at panelook, finding them is a different problem..)
Stuff like wifi and the such.
The 240Z in particular is quite interesting; closest I can get to a Thinkpad netbook.
Issues are:
Dorkstation: T601f
Ultraportable: X61s
Ultraportable: X61s
Re: Best classic traveling companion?
The 240Z is BEYOND RARE. There are just a handful of units left in the wild. The 570E isn't too rare, but can be a little tricky to find. They both have XGA, not UXGA. All the batteries for these machines are long since dead so rebuilding is a must and then I don't know about battery life.
Typically most notebooks till Tx20 and 15W CPUs era are usually 3 hours and very rare ones makes to 5+ hours range. Just hunt down a ivy-bridge 17W or haswell 15W notebooks and go from there and they are more lighter and smaller, good 6 hour plus range with 6 cell battery pack or internal battery. I'd look at 13.3" to 12.5" with 15W processor for good portability and is not expensive, new battery packs easy to come by.
People who said finding older notebooks with pentium/PII era is not easy and parts hard to come by is correct. Besides they don't last on battery charge either even you are lucky to rebuild into a
perfect 100% battery. Also costly too. I looked at 380XD yesterday and they were more than 200 dollars let alone battery condition.
Cheers, thinkpadcollection
I dropped the idea for now. Was really looking forward to trying an 240, but eh.
By the way, is there any better wifi card than the intel 2200 PRO for those machines? The PCMANIA wifi cards makes me feel like I'm using a dongle..
Dorkstation: T601f
Ultraportable: X61s
Ultraportable: X61s
You aren't wrong about there being many peripherals. Even the wifi on the 240 is a PCMCIA peripheral card.
MadIceTea, Thinkpad Enthusiast
Daily: X250 FHD
Museum: PC110 20MB, X61 T9300 SXGA+ LED
Donated: x2001 AFFS i5-530 (to my alma matter)
Past: 701Cs German, 535/X, 760E/XL, i-series 12/14xx, piano s30, R60e, X60, X61, T60, T61, X200 P8700, X121e
That chicken sure looks funny.
Daily: X250 FHD
There are "Atheros mini pci wifi N" cards. The chip is a 91xx or 92xx. I can get exact details if you need them.
Are you sure you have the 2200 and not a 2100? The 2200 is a G card and shouldn't be THAT slow. The 2100 is only a B card, and is really slow.
Yep! But keep that a secret
To be honest, that one was the best I found. If you have a better suggestion, that would be appreciated.jaspen-meyer wrote: ↑Tue May 15, 2018 12:22 amAre you sure you have the 2200 and not a 2100? The 2200 is a G card and shouldn't be THAT slow. The 2100 is only a B card, and is really slow.
Dorkstation: T601f
Ultraportable: X61s
Ultraportable: X61s
In my x24 I use a Qualcom Atheros AR922x -- bought from an ebay seller in Israel.
https://www.ebay.com/itm/Atheros-AR9223/322223141848
Classic ThinkPads installed in IBM System/390 and zSeries mainframes
by ThinkDan » Mon Nov 27, 2023 4:39 pm » in ThinkPad Legacy Hardware - 13 Replies
- 4727 Views
Last post by ThinkDan
Fri Feb 02, 2024 4:18 am
T580 Compared to Classic Thinkpads and Macbook Pro
by MisterB » Fri Mar 15, 2024 12:51 pm » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 341 Views
Last post by MisterB
X230 - what SSD will best fit in the WWAN slot?
by br1anstorm » Tue Nov 14, 2023 3:59 pm » in ThinkPad X230-X280 / X390 Series - 15 Replies
- 6235 Views
Last post by br1anstorm
Wed Nov 15, 2023 6:17 pm
What's the best way to remove paint from stock Thinkpad coolers?
by cultOfThinkpad » Sun Dec 10, 2023 6:52 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 1 Replies
- 4518 Views
Sun Dec 10, 2023 12:55 pm
