IBM Thinkpad 770 - Wont boot without PSU
Hi All,
I am new to the forums and have had a good search but cannot find my exact issue.
I have an IBM ThinkPad 770 in amazing condition. I received it with a dead battery and have replaced the battery.
The Laptop will boot, charge and run of the battery however if I shutdown or power off the Laptop it wont power back on until I plug in the power supply.
If I remove the power supply immediately after it will continue to work for well over an hour.
Has anyone else seen this type of issue?
Thanks for your help.
Jamie
Jamie
Re: IBM Thinkpad 770 - Wont boot without PSU
In this specific case, I have not heard of such a problem ever before. I think maybe you should check to make sure that the cells in your new battery hold enough capacitance [not the amount of juice, as the flow rate of it, per se] that they can start a machine (which requires an amount 'x' more power than the sustained amount to keep an already-on machine running).jamiecruickshank wrote: ↑Thu May 10, 2018 10:59 amHi All,
Jamie
I envy your battery pack, do you re-cell your own or did you find a rare top-grade battery out there?
MadIceTea, Thinkpad Enthusiast
Daily: X250 FHD
Museum: PC110 20MB, X61 T9300 SXGA+ LED
Donated: x2001 AFFS i5-530 (to my alma matter)
Past: 701Cs German, 535/X, 760E/XL, i-series 12/14xx, piano s30, R60e, X60, X61, T60, T61, X200 P8700, X121e
That chicken sure looks funny.
Daily: X250 FHD
Thank you for the reply,
I have tried 2 batteries in the machine. The battery that was purchased gives me just over an hour of use.
I have also replaces the cells in the original battery and again, it charges and runs fine but wont power up the machine.
I think there must be an issue with the DC board on the laptop as it has done it with two batteries.
Jamie
Jamie
Yes, if it is not the battery it can always be in the hardware as well - I'd check the DC power supply plug-in cable to the planar and, last resort, the planar itself.jamiecruickshank wrote: ↑Thu May 10, 2018 3:46 pmThank you for the reply,
Jamie
If you have a multi-meter handy, it shouldn't be a hard check.
Hopefully, you find a solution.
Daily: X250 FHD
Daily: X250 FHD
I have checked as much as I can on the DC board, however I couldn't find any schematics. The voltage does get to the board from the battery but without the Schematic, I am not 100% sure where to look.
I have repaired Laptop Boards before on component level but I have always had the schematics.
Jamie
Jamie
Ah. Unfortunately, I do not have the schematics either.
Hopefully someone more knowledgeable can assist with your case.
Daily: X250 FHD
Daily: X250 FHD
See if this helps: https://forum.thinkpads.com/viewtopic.php?t=70832
My suspect is probably that one of the capacitors are done for.
See if you can measure any faults with voltmeter over the capacitors
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
For electronics this old, I'm inclined to agree.
It would help if you have an oscilloscope and a copy of the schematics.
I did think it was the capacitors too, I have ordered a replacement set, there is only 2 through hole electrolytic capacitors and one surface mount.
I do have an Oscilloscope but I am in the process of moving house next week and its packed away at the moment.
They visually look okay however, I will replace them anyway. I managed to obtain a new DC / DC board for the machine and its on its way, I will let you know the outcome.
Oh and just a note, I tested the battery I purchased and got over 2 hours, I just bought it from eBay recently, which I thought was amazing for an old used battery!
Thanks for your replies,
Jamie
Jamie
I wanted to give everyone an update, I have bought a replacement DC/DC board and the fault still persists. I presume its going to be a motherboard fault as I have replaced every other component.
I was wondering, I seem to have a wire running on the motherboard under the RAM cover, its very professionally done and was wondering if anyone else has this? It looks like it was done from the factory.
Jamie
Jamie
forgot to mention, check all the fuses.
UXGA:
UXGA:
I had some issues like this, Id have to do the battery/button/AC trick to boot, I couldn't just do the battery/button...., Id still have to plug-in the AC/PSU to boot, then I could remove the AC, and it would work fine, but I couldn't power down with on/off button. Here's a link to what I found. Notice that I mention ware marks exposing traces on keyboard ribbon cable, I believe this to be the cause,,,, from vibration of HHD, Etc, and cable rubbing chassis over time. I should have taken pics.
viewtopic.php?f=48&t=126616
Thinkpad 770 Bios mod for cpu upgrade
by franjimo24 » Sun Dec 10, 2023 8:14 am » in ThinkPad Legacy Hardware - 6 Replies
- 5002 Views
Last post by solidpro
Tue Jan 23, 2024 4:02 pm
WTB: Thinkpad 770 Selectabase and Dock
by franjimo24 » Sun Dec 10, 2023 9:46 am » in Marketplace - Forum Members only - 0 Replies
- 1674 Views
Last post by franjimo24
WTB: Thinkpad 770 parts - LCD inverter, DC board...
by franjimo24 » Mon Jan 22, 2024 10:04 pm » in Marketplace - Forum Members only - 14 Replies
- 1247 Views
Last post by imperial4ever
Thu Mar 28, 2024 5:09 pm
- 14 Replies
- 974 Views
Last post by kapija
Wed Mar 27, 2024 1:46 pm
Users browsing this forum: No registered users and 46 guests
