770x type 9549 - RAM, CPU and Selectadock Questions
Hello.
I've recently bought a thinkpad 770x type 9549. And I decided that I wold like to upgrade the hardware in it. And just need a bit of clarification on some things.
So for the ram the most I can do is (2) 256megs pc100 sodimm and removing the onboard stick? Or should I use (2) 128megs sticks and (1) 256meg stick? 512megs total is still the highest possible?
For the cpu, is there any advantages for using a higher clocked cpu than a pentium iii 500mhz? Would it be worth the hassle to get the higher clocked cpu to work?
Also does anyone know where I can get my hands on a selctadock iii and the selectabase 770?
Re: 770x type 9549 - RAM, CPU and Selectadock Questions
ThinkPad 770X supports up to 320MB RAM. You have a 64MB RAM soldered on motherboard and two SDRAM sockets. Each of them can support 32MB, 64MB or 128MB (66MHz, non-parity, 3.3v) module. Official 128MB module have FRU number 01K1150.
Regarding SelectaBase, I've saw some on eBay. About SelectaBase, look for FRU/PN: 11J8822 or 83H6735.
EDIT: It seems, that information from PSREF is no longer accurate.
IBM 345C(PCDOS7.0+W3.11) | 390X(W95/W98SE) | T23(W2K)
R51(WXP) | Lenovo R61(WXP/Vista)
I dont think the ram is soldered because i see the edge of the third one next to the other slots.
The 770X and 770Z both support up to 512MB RAM.
On my 770Z, I use 256MB + 128MB in the main slots and then replace the onboard 64MB stick found in the back, hard-to-get-to slot with 128MB. 256MB chips used to be very expensive and hard to get, so this was the most efficient way to get the max ram. But you can also put 256MB + 256MB, and then the 64MB onboard slot is just ignored.
I think you might need to be careful about which 256MB sticks you get. Maybe they have to be "low density" with 16 chips on the stick? I'd have to doublecheck that.
Here is a historical thread where DK6400Brian and JHEM (James) reviewed and tested max memory options back in 2005:
ThinkPad 770 X/Z Memory matrice ?
X1E Gen 4 · X1T 3rd Gen · W520 · Legacy: P52, T60p, X61T, 600X, 770Z
Nostalgic for: 600X PIII 850MHz in a SelectaDock III with 64MB Voodoo 5 5500 and Sound Blaster Audigy 5.1.
If you can get a PIII 750 or 850, then yes, those will make a slightly noticeable difference over a PIII 500 in processor-intensive activities. However, if you get a PIII 650, then it will only run at 500MHz unless you do some fancy soldering (which I've never done). PIII 850MHz is the max, and it used to be very hard to find. I used to have one 770Z running PIII 500MHz and another running PIII 850MHz (running at 700MHz), and I only very rarely noticed any difference at all.
The PIII 650MHz and faster chips are all speed-step enabled, and because the 770X/Z motherboards don't support speedstep, the chips automatically drop down to their lower speed, which is 150MHz less. If you solder the right things, then you can force your chip to always run at its higher speed even in a non-speedstep motherboard like the 770X/Z.
Thanks for the info. The only Pentium III 850 one I see is listed for 90. Seems kinda high for a old laptop cpu. Wouldn't I also need to have a better cooler for the 850 if I go that route?
Yeah, that sure sounds high to me, too. But I think only one or two mainstream laptops (no ThinkPads) were built that used them in that MMC forum factor, so not many were manufactured. They used to go for somewhere between $100 and $150 back in the day.
No extra cooling required. If I recall correctly, even the PIII 850MHz ran as cool as the 500MHz, due to improvements in chip design. And if you let your 850 run at its stepped-down speed of 700, then it was actually cooler than a 500.
Cool.
I did find a selectabase 770, I think anyway. It's numbers are pn 11J9009 fru 05K7037. The lowest I was able to talk them down from $45 to $35 including shipping. Is this an ok price. Was trying to get it down around $20 or $25 but that didnt happen.
380ED display panel replacement - Type 1 and Type 2 panels?
by KylesDigitalLab » Thu Oct 26, 2023 11:26 pm » in ThinkPad Legacy Hardware - 0 Replies
- 1815 Views
Last post by KylesDigitalLab
Trouble Booting or Restoring 770X
by marchambault » Wed Oct 04, 2023 10:54 pm » in ThinkPad Legacy Hardware - 5 Replies
- 3593 Views
Thu Nov 09, 2023 11:52 pm
2 questions, RAM upgrade and OS downgrade on a W520
by NoPyro » Sat Dec 02, 2023 1:55 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 9 Replies
- 6764 Views
Last post by mikemex
Thu Feb 22, 2024 1:47 am
FS: Intel Core i7-3630QM CPU + RAM
by PiZzA EnGiNeEr » Mon Oct 30, 2023 12:26 am » in Marketplace - Forum Members only - 1 Replies
- 1711 Views
Last post by wilocampo
Thu Nov 30, 2023 2:59 am
Users browsing this forum: No registered users and 75 guests
