need advice with 380XD Win95 installation
hi guys.
i got an IBM win95 bootable diskette + Installation CD from ebay without knowing that the cd-rom driver on floppy may not be compatible with my 380XD cd-rom.now i get error message: ERROR Adaptect ASPI Device Driver not available (unable to find AIC-78XX/AIC-75XXASPI80DOS.SYS) every time i boot from floppy hence i am guessing the cd-rom drivers on this bootable diskette is likely belong to a different model IBM computer (hopefully the CD installation doesn't play up later!). this is my first vintage Thinkpad and i don't have any vintage peripherals. considering buying few blank 1.44 diskettes and a USB to 3.5" diskette external drive, download/copy the cd-rom drivers on a floppy and etc etc.
is there any other way to get the downloaded files/drivers from the internet onto my 380XD without investing on diskettes/external diskette player that is likely to be used once?
thank you for your help in advance
Re: need advice with 380XD Win95 installation
Try making a Windows 95 boot disk and accessing the R: (CD-ROM on that disk) If that doesn't work, try the newer W98 boot disk. That might have newer better drivers. Should work just as a basic IDEA OF CD-ROM though but there is no damage you can do. Just ise a different disk than the one you bought.
thanks for the help. i do have a Win95 bootable disk which i successfully boot from, fdisk, format and sys my C: drive with. however the cd-rom driver letter (R: or i expected it to to be D:) no where to be found. was i wrong thinking that built-in cd-rom drives do not need drivers and work out of the box from a Wind95 dos prompt?
Not sure if I am remembering correctly, but I think used to use a generic IBM cd sys driver when I was installing Windows 95/98 on 1990's era thinkpads. Looking at an old set of boot disk files, I see one named "IBMTPCD.SYS".
My AUTOEXEC.BAT file has a single line:
MSCDEX /D:TPCD001
(Which means you need to have the file MSCDEX.EXE on your boot disk).
And the CONFIG.SYS includes the lines:
DEVICE=HIMEM.SYS
DEVICE=SMARTDRV.EXE 2048 2048
DEVICE=IBMTPCD.SYS /R
(Which means you need HIMEM.SYS and smartdrv.exe on your boot disk as well).
I think that boot disk worked for most CDROMs in my Thinkpad 350C up to and including all my 600/770 series. Does that help?
Phil.
MSCDEX /D:TPCD001
DEVICE=HIMEM.SYS
Phil.
X1E Gen 4 · X1T 3rd Gen · W520 · Legacy: P52, T60p, X61T, 600X, 770Z
Nostalgic for: 600X PIII 850MHz in a SelectaDock III with 64MB Voodoo 5 5500 and Sound Blaster Audigy 5.1.
Thanks Phil, yes that was very helpful.
I will check the autoexec.bat file seeing what bootable disk is trying to load. my guess is currently what is loading is not the right driver for the installed cd-rom, hence the error message.
my main problem is lack of 1990's peripheral lol. no correct tools=no fix! i have now ordered an IBM USB to 1.44" drive plus some blank floppies so at least i can download files i need of the Internet, surely they will come handy with next vintage Thinkpad project
thanks for help guys
In really old Thinkpads, you couldn't always boot from USB because the USB port actually required some drivers to load first. And sometimes you couldn't even reliably boot from CD-ROM! I can't say about the 380XD. But you could always boot from a floppy drive - either one installed directly in the Thinkpad Ultrabay/UltraSlimBay/WhateverBay, or one that was connected to the unique floppy port via one of the proprietary IBM floppy cables (though different generations of Thinkpads would sometimes use different cables and connectors - there were two or three variations I think).
When working with old Thinkpads, those special external IBM Thinkpad floppy drives with their custom cables are very handy!
Thinkpad 600 driver problems under Win95.
by ThinkIsaac » Sun Mar 10, 2024 9:09 am » in ThinkPad Legacy Hardware - 1 Replies
- 243 Views
Last post by ThinkDan
Thu Mar 21, 2024 7:03 am
Need some advice to choose my new T60
by KadYmz » Sun Nov 19, 2023 2:50 am » in ThinkPad T60/T61 Series - 5 Replies
- 2206 Views
Last post by ZaZ
Thu Nov 23, 2023 5:32 pm
FS: X2100 with need of love and a new home.
by mcfado » Wed Nov 29, 2023 7:29 am » in Marketplace - Forum Members only - 2 Replies
- 1478 Views
Last post by lars-rasmussen
Thu Nov 30, 2023 6:30 am
Need to repair IBM USB ThinkPad keyboard
by ThinkPad560X » Sun Dec 03, 2023 1:01 am » in Off-Topic Stuff - 0 Replies
- 1808 Views
Last post by ThinkPad560X
