PC110 CF Card Image?
Hi Everyone
I recently shared an image of a factory restored 701C but I am now working on a PC110.
Display is a dead loss, but I do have it working via a port replicator and an external monitor.
However I have no flash card or know where to start with restoring it. I think this was built to run Win95 and I've seen some custom IBM menu system for it. Does anyone know where I can get these original installers, or would anyone be kind enough to share a CF card image of a restored machine?
Re: PC110 CF Card Image?
I have dumped a bunch of PC110 software images here: https://archive.org/details/pc-110-repository
Wow, many thanks for sharing that, much appreciated!
Hi Solidpro
Thanks for the great resources on archive
I can't find my pc110 floppy drive, any chance you could make a small CF card image with the original dos7 and at some utils like sys so I can restore the internal 4mb? The other files I can load from extracts of the images, but I've been complete unsuccessful with generating working bootable CF card from the restore disks
Thanks either way
matrx
Thanks either way
matrx
Hey Matrx
Sure I could do it. I think I did do it..... let me check the archive.org stuff I posted... All you'd need is for it to be bootable and then you can copy over what else you need in a CF reader...
From distant memory have you made sure it's set to boot from the correct hard drive in the BIOS? I think there are 2/3 available and you need to make sure they're in the right over, otherwise it boots from the built-in storage...
I accidentally sys'd the internal drive with win95. It boots but it isn't great -- my bootable backups all depend on the floppy drive which i can't find. If it's not too much trouble, it'd be great. If not, I can build one in a VM.
matrx
matrx
What size CF card? The max I have is 8Gb. I can use my floppy to just make it bootable to Dos7 or whatever and image it....
I don't think the size makes much difference, something small can ususally be written to a larger medium with wasted space
If I can squeeze in the time tomorrow, I'll do it. I am about to go away for a week on Wednesday but can and will do it for you if I don't make it tomorrow.
In going over my various PC110s I've remembered that one of mine has a keyboard with a ribbon cable that has split in 2 (I think caused by a leaking battery). I don't suppose you have a spare keyboard!?
cheers
cheers
- 0 Replies
- 2294 Views
Last post by ThinkDan
Sun Oct 22, 2023 8:33 am
- 0 Replies
- 356 Views
Last post by solidpro
Thu Feb 08, 2024 9:30 am
- 2 Replies
- 266 Views
Mon Mar 04, 2024 2:07 pm
PC110 Restoration stuff [HUGE PICS]
by solidpro » Wed Mar 06, 2024 1:10 pm » in ThinkPad Legacy Hardware - 2 Replies
- 337 Views
Sun Mar 10, 2024 5:35 am
