Anybody know of a source for the battery connector on the top system board? Do any other models share this same connector? The only markings on it are MX-IT and the number 3.
Picked up a 701C at an estate sale where the battery had leaked quite badly. I submerged the battery connector in vinegar to try and salvage it, but the electrolyte had eaten through one of the contacts. Realistically, I'll probably never be using the computer far from a wall socket but I'd like to keep the system as close to original as possible.
701C Battery Connector
Re: 701C Battery Connector
I had the same problem with mine. But I was lucky to have a spare motherboard. BUT a connector on that one was damaged too, so I de-soldered both, took two of pins out from one connector and installed in the other one. Surprisingly it worked and there was enough metal left on the pin to survive bending in the process. I have not managed to locate a seller of new ones. In your case I would recommend to find a suitable piece of metal, cut it in the form of the pin and install it. It might work.
P51s ssd connector malfunction
by PieterVanHecke » Fri Mar 22, 2024 11:26 am » in ThinkPad P1/P40/P50/P70 and later Series - 6 Replies
- 596 Views
Last post by PieterVanHecke
Mon Mar 25, 2024 4:44 am
Switching a 701c screen onto a 701cs laptop?
by solidpro » Thu Nov 09, 2023 1:32 pm » in ThinkPad Legacy Hardware - 4 Replies
- 5203 Views
Last post by ThinkDan
Fri Nov 10, 2023 6:44 am
- 3 Replies
- 1826 Views
Last post by Gonzaleitor
Tue Nov 28, 2023 4:19 pm
ThinkPad 701C with AMD upgrade on ebay
by ThinkDan » Mon Dec 04, 2023 10:01 am » in Marketplace - Forum Members only - 1 Replies
- 1583 Views
Last post by H-Atkinson
Thu Dec 07, 2023 10:33 pm
Users browsing this forum: astral, kfzhu1229, panips, Psyberducky and 19 guests
