#2
Post
by solidpro » Tue Sep 13, 2022 9:47 am
It's almost impossible to find, so I built my own. The connector is a very unusual 4 pin connector which is a bit bigger than a S-Video or PS2 male connector. However if you remove the outer shield from either of those, it'll fit, with the S-Video connector having the key in the right position.
If you look directly at the socket on the side of the PS/Note, the top left hole is GND and the bottom 2 pins either side are 22v +
One is for battery and one for 'power' but I found you have to power both for the machine to turn on, whether it has a battery or not. I tested with a variable power supply and it draws a max of about 1.4amps so you need anything +19 / 2a really and you should be in business.
WANTED: 220, 300 ,240Z, 300C, 315D, 320, 330x, 345x, 350x, 355x, 360x, 365x, 385x
ANY 5xx Series, 700, 700C, 701CS, 720, 720C, 730TE, 750, 750C, 750P, 755CD, 760x, 765x, 770x
ANY 8xx Series, A20P, A21p, A22p, A30p, A31p, R30, R50, R50p, R52, T40p, X23/4, X40
