Hi All
I managed to get an IBM Thinkpad 770 from ebay for about £60, which appealed to me because I would say 75% of the 770 machines out there have a terrible condition in their palm rest where whatever IBM were using to coat and paint it, was an early bad design that reacts easily to either wear of the human wrists or the grease and oils in the skin. So they generally look like they're been melted with acid on one side - and this one was pretty perfect!
It is in early stages of stickiness for the base, but it's not bad enough to actually come off in your hands, so I've left it for the time being.
However, what I did do was replace all the electrolytic capacitors and I did have to remove a SVP password on it. So I thought I would take a few pics. Especially as I've seen a few people say that the 770 is a bit of a nightmare to strip down - which isn't the case.
I didn't take pics of the whole process, but there is essentially screws on the bottom to remove, 4 along the top of the keyboard and then the keyboard and kb bezel pops off with 4 ribbon connectors underneath.
Then you have to carefully remove the 4 hinge screws and the LCD/lid pops off with just two sturdy wires to disconnect. Note in the next pic there is a horrible, time-bomb, varta hibernation battery nestling in the middle/left hand side. Get that out ASAP! I've not actually found any corrosion in a 770 variant yet, but they're all just sitting there, ready to spread!
Then you have to pull out the front speakers and unscrew one screw in the middle holding the two locking plastic tabs in place which release the battery and optical drive. You just slide it up and off. Finally you have to remove about 8 or so screws to remove the aluminium shielding, which reveals the 3 x boards; 1 mainboard, 1 DC/DC/connector board and 1 for graphics.
As far as capacitors were concerned, there were only 5 electrolyic in the whole thing - 2 x through hole 100uf / 16v ones and 3 x surface mount ones (100uf x 2 and 47uf) which can be replaced with tantalums.
DC Board:
Motherboard:
To get to the 24c01a, you do have to strip the machine back to it's boards, but you can lay it out on a table, connect up the keyboard and an external VGA display and do what you need to do fairly easily
And then just do it all in reverse! Hopefully you're left with zero screws and a working machine! Good job all round. Amazingly the main lithium battery still charges and the whole machine is preserved for another 30 years - maybe with the exception of a de-rubberising at some point in the future! Booted into the stock 4Gb HDD's Windows 98.
Strip down and fix up a decent 770
Re: Strip down and fix up a decent 770
those purple caps marked os-con are polymer capacitors, not electrolytic. no issue with replacing them but just so you know in the future - those don’t need to be swapped. no electrolyte liquid inside of them.
Your average ThinkPad collector.
Owns: T480, Yoga S1, modded T430, T61p, R60e, T43 14" SXGA+, G40, T30 SXGA+, T23, A22p, T21, i1260, 385XD, 560, PS/Note 425
Oh really? I didn't know such a thing existed. Why didn't they use solid caps for other machines?!
more expensive. that tech was pretty early days in the 90s too.
WorkPad Z50 strip down and clean up [WARNING: PICS]
by ThinkDan » Fri Feb 02, 2024 5:56 pm » in ThinkPad Legacy Hardware - 3 Replies
- 680 Views
Last post by ThinkDan
Sun Mar 10, 2024 6:54 pm
WTB: Thinkpad 770 Selectabase and Dock
by franjimo24 » Sun Dec 10, 2023 9:46 am » in Marketplace - Forum Members only - 0 Replies
- 1674 Views
Last post by franjimo24
Thinkpad 770 Bios mod for cpu upgrade
by franjimo24 » Sun Dec 10, 2023 8:14 am » in ThinkPad Legacy Hardware - 6 Replies
- 5000 Views
Last post by solidpro
Tue Jan 23, 2024 4:02 pm
WTB: Thinkpad 770 parts - LCD inverter, DC board...
by franjimo24 » Mon Jan 22, 2024 10:04 pm » in Marketplace - Forum Members only - 14 Replies
- 1246 Views
Last post by imperial4ever
Thu Mar 28, 2024 5:09 pm
Users browsing this forum: Enig and 50 guests
