IBM Thinkpad 240 - boot from USB or virtual drive via USB?
thinkingpad11
#1 Post by thinkingpad11 » Sun Jul 23, 2023 1:09 am
I have found a nice 240 with a celeron 400, and it came without the drive; so I got a ide to sata and installed a 64 GB drive in it; but it seems that these machines do not have the bios set to boot from CD via USB. So if I plug a CD or a floppy via USB, it won't boot.
I could not find neither the floppy drive nor the Cd rom (both proprietary; the floppy is a weird cable and the CD rom use the PCMCIA port); so I am stuck basically.
The computer just boot and expect either a "legacy floppy" (the original IBM external floppy), or the main disk; the bios has nothing else. How do I solve the boot issue? I would like to make it a dual boot (dos and W98) machine; so I can use both environments, but as is now I can't even install one OS. Is there any updated bios that would let me use the CD rom or floppy as boot via USB? Or is there something else I can use to fool the bios to believe that it is using the official IBM floppy or CD rom? I was looking at this to simulate the CD rom; not sure if that would work: it seems that it can use ISO of CD roms as if it was a real drive, and can mount also IMA files from floppy and virtual drives
https://www.amazon.com/dp/B0B3HQMV5T
Ponow
Re: IBM Thinkpad 240 - boot from USB or virtual drive via USB?
#2 Post by Ponow » Mon Jul 31, 2023 6:31 am
Try removing your SSD, then install it in another computer and install a bootable OS (Win98) onto that SSD. Then put it back on the Thinkpad 240. That should be bootable. I think Win98 has a DOS mode.
I haven't tried this though! So no guarantees.
#3 Post by ajkula66 » Thu Aug 03, 2023 2:12 am
The problem here will be finding another PC that will play nicely with 240's BIOS. ThinkPads of this era are not keen on booting from the OS on a disk installed in a different system.
Getting the proprietary IBM CD drive is about the only way out in my recollection, which may be faulty since I haven't toyed with 240s in about 15 years.
Good luck.
Abused daily: T520, X200s
#4 Post by axur-delmeria » Thu Aug 03, 2023 10:49 am
I think the underlying issue is the Thinkpad 240's BIOS and CHS parameters.
Newer computers (and USB->IDE adapters) will just use LBA addressing, but the 240 might still be using some sort of LBA -> CHS translation.
Old Faithful: X220 4291-C91 i7-2620M
