I believe my Thinkpad 300 was an NOS. It's sealed, but the screen is really bad due to its age. I just got no time working on it for 1 year, until I finished my work on 700c and 720c.
Since I heard a lot of negative feedbacks on the thinkpad 300, I managed to get an (almost) working Zenith Data System 325L before starting to restore it, thinking that at least I can transplant everything to that thinkpad. So I spent quite a bit time repairing the 325L and make it work, and then opened my box and took out the brand new 300. It's not as bad as I was thinking. In fact it boots, although it is not stable and the VGA output seems buggy. I feel like the random characters it outputs to the external monitor might be caused by power supply of its mobo, so a full recap seems to be necessary before any further debugging. BTW, this is a really old laptop, you may need a monitor supporting 15/30kHz.
There is a lid to the top right of the keyboard, under which there are slots for memory and 80387sl. Slide it to the right and lift from its right end first.
On the back side, after removing the battery, there are 5 screws.
and another 3 screws to secure the top case
carefully lift up the top case and LCD assemble, there are two cables, 1 flat cable is the power/status indicator cable, another on under the hinge is for the LCD.
by removing the LCD assemble, you can see 2 flat ribbon cable and one screw to secure the keyboard
And 4 screws (red) for the System and I/O board. Don't forget another 2 (yellow) on the I/O panel
Here is the view from the back:
The system board is connected to another power/ south bridge(?) board by 2 connectors, lift up it carefully. Here is how the connectors look like:
rest of the parts are easy, 3 screws for the HDD and 1 screw for the FDD. Lift up the HDD and disconnect it, for FDD, slide it to the left and lift it up to remove it.
Two other cables for the CMOS battery and speaker. I'll talk about the battery later but remove it as soon as possible
Five more spacers and you can take out everything
Recap is trivial so I'd share some experience on battery and lcd later.
