How can I get OpenGL 3.x suppoet for Edge 057922U?
It looks like this thing only supports up to 2.1.
Re: How can I get OpenGL 3.x suppoet for Edge 057922U?
Hi, Have you checked it with opengl extension viewer ? What is it reporting? As far as i can see if you are running Win7Pro 64 latest driver by intel is the Version: 15.22.58.64.2993 (Latest) Date: 2/19/2013, what driver you have ?
I'm running Linux mint on it. There's a similar program out there called gpu viewer, but I recall having difficulties getting it to install on another laptop due to lack of vulkan support.
A quick google search on that model number reveals that it has a 1st generation Core i3/i5 processor (Arrandale). Unfortunately, according to this Intel GPU listing from Wikipedia, that generation only supports OpenGL 2.1. You need a Sandy Bridge laptop (2nd gen Core i series) to get OpenGL 3.3, and Broadwell (5th gen Core i series) or newer for full Vulkan support (3rd and 4th generations only partially support Vulkan).
Lost wireless on t420 - can’t get it back
by Dd777 » Mon Dec 04, 2023 7:10 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 11 Replies
- 4697 Views
Last post by Dd777
Wed Dec 06, 2023 1:39 pm
Can you add a GeForce GPU in a G41 with Intel GPU?
by Gonzaleitor » Thu Oct 26, 2023 1:51 pm » in ThinkPad R, A, G and Z Series - 2 Replies
- 5717 Views
Last post by Gonzaleitor
Thu Oct 26, 2023 5:22 pm
Thinkpad P71/Xeon (with ECC memory) - can I use two 32GB SODIMMS?
by wb0gaz_h » Thu Nov 02, 2023 5:05 pm » in ThinkPad P1/P40/P50/P70 and later Series - 0 Replies
- 3405 Views
Last post by wb0gaz_h
Internet Speed Test, who can you believe?
by RealBlackStuff » Tue Nov 14, 2023 3:51 am » in ** HOW TOs & FAQs ** - 20 Replies
- 7601 Views
Last post by ajkula66
Mon Feb 19, 2024 8:21 am
