Intermittent chirping sound
X1/X1-Carbon series specific matters only
Takeda
#1 Post by Takeda » Mon Sep 18, 2017 10:21 am
A friend of mine has a X1 Carbon that makes an intermittent chirping sound. Pressing the "mute" button eliminates the chirping sound.
Thinkpad4by3
Re: Intermittent chirping sound
#2 Post by Thinkpad4by3 » Mon Sep 18, 2017 11:19 am
Most likely a software problem. Download and run malwarebytes. My computer used to do a similar thing.
Probably should be Thinkpad16by10.
Looking For: 386 laptop, IBM or not.
Takeda
#3 Post by Takeda » Mon Sep 18, 2017 2:16 pm
Thank you! I'll try that!
Takeda
#4 Post by Takeda » Tue Sep 26, 2017 4:58 pm
I downloaded malwarebytes, and ran it. 61 threats were found, and quarranteened. Unfortunately, the intermittent chirp is still there
Takeda
#5 Post by Takeda » Tue Oct 24, 2017 7:32 pm
Any other suggestions? Thank you!
Cigarguy
#6 Post by Cigarguy » Tue Oct 24, 2017 8:12 pm
I'd try a live Linux distro just to see if the problem is software. If it is chirping in Windows but not Linux then a fresh Windows install might be on order. If both chirping is from both OS then it's hardware.
Thinkpad4by3
#7 Post by Thinkpad4by3 » Tue Oct 24, 2017 8:23 pm
Windows rebuilds can give random error messages at inconvenient times :lol: .
Why not use a Linux Live CD and test it that way?
Takeda
#8 Post by Takeda » Thu Oct 26, 2017 3:45 pm
Thank you for your suggestion!
I'll try the Linux suggestion.
Takeda
#9 Post by Takeda » Thu Oct 26, 2017 3:46 pm
Return to “ThinkPad X1/X1-Carbon”
