X1 Carbon with 1TB SSD
Can I install a 1TB SSD on a 2nd, 3rd or 4th Gen X1 Carbon ThinkPad?
My ThinkPad Graveyard:
600 * 2, X220, X61 * 2, T61
Re: X1 Carbon with 1TB SSD
Even up to 2TB without any problem.
We have X1C4 (X1 Carbon Gen 4), and can confirm that it supports NVMe SSD for both 1 TB, and also 2 TB, done via Product Recovery.
We also have X1C3 (X1 Carbon Gen 3) which *does*not* support NVMe, because it uses a tech deadend ACHI interface of dual sided SSD which is out of production,
we did not bother to try other SSD on it.
Heard that you can add in "Sata" type of "2280" dual sided SSD into X1C3 albeit at slightly slower SSD speeds, but we have never tried this ourselves.
In short, if you wish to at least future-proof your NVMe SSD storage solution, stick with X1 Carbon Gen 4 or later models.
Can you provide details about which 2TB drive works?
Samsung PM981.
We used Samsung 970 Evo Plus (NVMe PCIe "2280" single-sided), both 1 TB & 2 TB confirmed to be OK on X1 Carbon Gen 4 (X1C4).
Yeah i have the X1 3rd gen and it will see NVMe drives and read/write from them, but it refuses to boot from them. Apparently you can make a bootable USB drive with Clover installed (an open source bootloder, primarily used for making Hackintoshes) to boot a NVMe SSD, but so far I've been unsuccessful in getting it to work. I'm planning on loading it onto a tiny Cruzer Fit USB drive as i have a spare 1TB NVMe drive I'd like to use instead of the smaller drive in the laptop now
https://forums.lenovo.com/t5/ThinkPad-X ... -p/4487943
The X1 Carbon Gen 3 (X1C3) was designed to support NVMe during the planning stages--until Samsung suddenly announced that its PM951 (3D NAND PCIe "2280" SSD max 500 GB) suddenly will not support NVMe as Samsung was not ready. And Samsung announced this just before X1C3 was about to be announced/launched.
Hence X1 Carbon Gen 3 only supported the tech deadend ACHI SSD, or the slower SATA "2280" SSD.
I've never seen any details as to how ThinkPad disabled the NVMe support for X1C3:
a) Purely BIOS disabling NVMe support?
Perhaps. Very very early Lenovo Forum poster claimed that he could get X1 Carbon Gen 3 to boot into NVMe SSD, by pressing [ESC] during bootup error.
Then a BIOS patch shortly after that disabled even this above function.
ie: X1C3 cannot bootup from NVMe SSD anymore after that.
b) Hardware removal in X1C3 to remove NVMe support?
No idea if ThinkPad did this either.
betonhaus wrote: ↑Mon May 03, 2021 3:09 pmYeah i have the X1 3rd gen and it will see NVMe drives and read/write from them, but it refuses to boot from them. Apparently you can make a bootable USB drive with Clover installed (an open source bootloder, primarily used for making Hackintoshes) to boot a NVMe SSD, but so far I've been unsuccessful in getting it to work. I'm planning on loading it onto a tiny Cruzer Fit USB drive as i have a spare 1TB NVMe drive I'd like to use instead of the smaller drive in the laptop now
I think I know something that might work and I'm going to pull apart my system to try, but any details I can know in advance would be helpful.
I have a ssd that has a clean install for that computer because I tried installing, but it refused to boot. If I boot from the installer and open command prompt, I should be able to clone the efi partition to the USB drive, delete the original partition, and it will boot from there. The partition will already point to the correct bootloader on the os partition, but I might need to edit a line so it points to the correct drive.
I asked around and got this advice
i get the error on detection ssd error that tells me to hit escape, then I can click the enter menu but then I just get a black screen. i feel like the instructions would work, if I could just get the installed usb to launch so i can enter command prompt
Trying that but now my computer refuses to boot to even the USB installer when the nvme drive is installed :/NavyLCDR;2223820 wrote:I have an NVMe SSD. I just inserted a USB flash drive with a FAT32 partition on it. My Windows on the NVMe SSD is C: drive. The USB flash drive got drive letter F:. I just ran the command:I rebooted my computer from the flash drive and it booted into Windows on my NVMe SSD. That's all you need to do.Code: Select all
bcdboot C:\Windows /s F: /f UEFI
X1 Carbon 5th gen upgrade suggestions to recent model carbon/yoga/nano
by meeotch » Sun Oct 15, 2023 4:32 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 8 Replies
- 13388 Views
Sun Dec 17, 2023 1:32 am
- 0 Replies
- 4059 Views
Last post by bjain29
Mon Nov 20, 2023 9:28 am
What are the best X1 Carbon (generation) Thinkpads?
by Hans Gruber » Mon Oct 02, 2023 1:30 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 6 Replies
- 5607 Views
Last post by Ibthink
Sun Dec 31, 2023 9:40 am
X1 Carbon 11 gen External Hard Drive Random Disconneciton
by narrownico » Thu Oct 19, 2023 11:39 am » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 5 Replies
- 3324 Views
Last post by DenverBrian
Wed Dec 20, 2023 1:44 pm
