X1 Carbon Gen 8 can't change charge levels via TLP 1.3.1 in Ubuntu 20.04
eggrevolver
#1 Post by eggrevolver » Sat Aug 28, 2021 5:32 am
I've got a new X1 gen8 with core i7 10510U CPU. I've installed Ubuntu 20.04 and tlp, were successfully changing charge levels up until this moment. I guess, I've installed some regular update and it doesn't work anymore :( When I try to do anything via tlp it tells `Error: battery charge thresholds not available.`
$ uname -r
5.11.0-27-generic
$ sudo tlp-stat -b
--- TLP 1.3.1 --------------------------------------------
+++ Battery Features: Charge Thresholds and Recalibrate
natacpi    = inactive (laptop not supported)
tpacpi-bat = inactive (laptop not supported)
tp-smapi   = inactive (laptop not supported)
One of those must be supported afaik... I've checked tlp faqs and found nothing about this issue.
Does anyone know what may be causing this?
eggrevolver
Re: X1 Carbon Gen 8 can't change charge levels via TLP 1.3.1 in Ubuntu 20.04
#2 Post by eggrevolver » Mon Aug 30, 2021 5:40 am
Ok, I've found the problem. I was messing up with thinkfan and broke `thinkpad_acpi` config, modprobe was unable to load it:
$ sudo modprobe thinkpad_acpi
modprobe: ERROR: could not insert 'thinkpad_acpi': Invalid argument
contents of `thinkpad_acpi.conf` were:
cat /etc/modprobe.d/thinkpad_acpi.conf
options thinkpad_acpi fan_control=1
options thinkpad_acpi fan_control=7
leaving the only first line cured everything, `thinkpad_acpi` is loaded and `tlp` works via `natacpi`:
sudo tlp-stat -b
natacpi    = active (data, thresholds)
tpacpi-bat = active (recalibrate)
tp-smapi   = inactive (ThinkPad not supported)
