I'm in the market for a new laptop after almost nine years with a Macbook pro late 2008. I want to use it with my bicycle trainer, some coding, some HD video editing and photos, and mostly just arguing on the Internet . The price point of the t440s and p is just right. But is there other options that take daily use, have a long battery life and is silent in use? And how much more noisy is the p model?
Sent fra min F8331 via Tapatalk
T440s or s? Or other?
Currently Thinkpad t470s i5-7300u and Thinkpad t61p T7700
Previous: Thinkpad x61s L7500, Thinkpad a22p and Thinkpad 365x
Re: T440s or s? Or other?
Hi.
I have a T440p with a Core i7.
I have to run that thing on "minimum" CPU power always so "Maximum Battery Life" is used in Power Options, otherwise that thing would get very hot, CPU temperatures in the range of 55-65C. When using with 5% of CPU power it can stay at 44-50C with the fan set to Mode 1 using a software that controls the fan at 3,000rpm.
I don't have experience with the T440, but having owned a T450 and T460 those machines run very cool, specially the T460. The processors use a TDP of 15W version the 47W Core i7 on the T440p although you can use a normal Core i5 with 35W I believe.
You can put a Full HD screen panel on a T440/p without problems, the normal LCD panels these models come with are rubbish.
Bare in mind that on the T440 the screen bezel is a plastic sheet with glue, usually putting a FHD screen such as the AUO B140HAN01.2 the lower part of the LCD would bulge, and from time to time the screen plastic bezel would not be in close contact with the LCD resulting on a minor aesthetic detail.
On the T440p you have a hard plastic bezel and the job is spotless.
If you want battery life go with either the T440/s, these have dual batteries, and you can use the even bigger 72Wh battery + the 24Wh internal battery so you will get awesome battery life
Current
T440p: Core i7-4710MQ|16GB RAM|Intel 200GB SSD| 14.1" AUO IPS FHD|Win 7 Pro|T450 Trackpad|Backlit keyboard|2nd Caddy
T460p: Core i5-6300HQ|16GB RAM|lPNY 256GB SSD| 14.1" Panasonic IPS WQHD|Win 7 Pro
Thanks. I was put off by the power consumption and the lack of physical buttons. So I ended up getting a slightly used t470s.
T440s won't turn on
by hedron » Sun Mar 31, 2024 10:31 pm » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 244 Views
Last post by hedron
Mon Apr 01, 2024 3:26 am
What other models have compatible touchpads to the t60?
by Glaurung-quena » Sat Nov 18, 2023 11:20 am » in ThinkPad T60/T61 Series - 2 Replies
- 1714 Views
Wed Dec 27, 2023 6:26 am
