I have a T440p which came with a non backlit keyboard, which I wanted to replace it with a backlit one. After installing the new keyboard the backlight wouldn't come on (i'm using Fn + spacebar, the keyboard has the light icon on the spacebar and the OS shows an icon for the backlight). I tried swapping it out with a friend's keyboard (from a t450s which was replaced due to a damaged key) but without any luck.
Could this be an issue with the motherboard or controller? What are my options?
T440p keyboard backlight issue
Re: T440p keyboard backlight issue
My prediction is that its just a regedit fix. Probably is similar on how an regedit fix is needed to enable physical buttons when swapping X250 touchpad in X240.
Could you, please, point me in the right direction?
It doesn't work with either linux nor WIN10 (a clean install). This page https://support.lenovo.com/fr/en/solutions/ht104656 also states that it's a hardware feature. It doesn't even light up when in BIOS.
I would love to find a software fix for this, but it seems less and less plausible at this point.
My T440 NOT A P is this > "Ctrl" + Spacebar, First function is on, another is BRIGHTER and another is OFF.Kuzman wrote: ↑Wed Aug 02, 2017 2:49 pmI have a T440p which came with a non backlit keyboard, which I wanted to replace it with a backlit one. After installing the new keyboard the backlight wouldn't come on (i'm using Fn + spacebar, the keyboard has the light icon on the spacebar and the OS shows an icon for the backlight). I tried swapping it out with a friend's keyboard (from a t450s which was replaced due to a damaged key) but without any luck.
T60 2007-GCU T7200 2.0GHZ/2.0G 3945ABG XP (Bluetooth & ATI FireGL V5250 by "Brad")
600 2645-A2U used only for "data logging" my 1990 Corvette ZR-1
T440p no display, external monitor works
by xexexexex » Fri Sep 29, 2023 6:57 am » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 2543 Views
Last post by xexexexex
FS: ThinkPad T440p
by PiZzA EnGiNeEr » Tue Oct 31, 2023 3:43 pm » in Marketplace - Forum Members only - 4 Replies
- 1606 Views
Last post by PiZzA EnGiNeEr
Sun Mar 03, 2024 5:17 pm
T440p + Ultra Dock, but dock video out (HDMI) not working
by Arf the Lab » Sat Nov 04, 2023 6:58 pm » in ThinkPad T430-T490 / T530-T590 Series - 6 Replies
- 4199 Views
Mon Nov 06, 2023 1:39 am
thinkpad t440p Linux trackpad + trackpoint not working.
by jaggreaney » Thu Nov 09, 2023 2:54 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 2110 Views
Thu Nov 09, 2023 11:48 pm
