t440s upgrades
t440s upgrades
I recently got my first thinkpad - t440s and i'd like to replace that awful 1600x900 screen and touchpad.
Is aliexpress ok site to buy part(s) from I was thinking of buying touchpad there:
https://www.aliexpress.com/item/Three-K ... 98840.html
and screen from laptopscreens:
https://www.laptopscreen.com/English/mo ... ash=152880
Re: t440s upgrades
Welcome to the Forum.
Aliexpress is often a roll of the dice, but often cheaper than elsewhere.
And if you read Laptopscreens's description:
For the LCD replacement, see this: https://thinkpadmint.blogspot.co.uk/201 ... t440s.html
you never know WHAT you get from that outfit! I'd say: avoid!- New Grade A+
brand new part made by one of the above mentioned major manufacturer.
Re: t440s upgrades
Thanks, glad to join you.
But where should i buy AUO screen? anywhere where i can be 100% certain that i'll get that exact screen and not say LG one?
I guess i'll buy touchpad then from aliexpress, it has 44 feedbacks and all of them are positive.
Re: t440s upgrades
Read this (very long) post for where to get those LCDs: viewtopic.php?f=45&t=122224
Re: t440s upgrades
found this
http://www.lcd4laptop.co.uk/ibm-lenovo- ... creen.html
ANd got confirmation from them:
We currently have the AUO in stock, however the part number we have is B140HAN01.3 which should and will not make a difference and will work with your laptop.
so i'm going for it. i hope it will work as expected. also bought that touchpad. fingers crossed
Re: t440s upgrades
If they confirmed you the model number then you will be fine, I've bought 2 AUO B140HAN01.2 from AliExpress from two different sellers and the displays have been flawless, one is on my T440p and I've the other as backup.
Current
T440p: Core i7-4710MQ|16GB RAM|Intel 200GB SSD| 14.1" AUO IPS FHD|Win 7 Pro|T450 Trackpad|Backlit keyboard|2nd Caddy
T460p: Core i5-6300HQ|16GB RAM|lPNY 256GB SSD| 14.1" Panasonic IPS WQHD|Win 7 Pro
Re: t440s upgrades
mzezelj , Any feedback on the replacement Touchpad? I've carried a Thinkpad since the T20 days and I'm dying with the Touchpad on my T440!
Re: t440s upgrades
I was suffering with the touchpad in windows but find that it works much better after installing cloudready(chromeos). I'm planning to upgrade the panel as the 1600x900 one is awful under any operating system.
Currently ordered aliexpress panel and kingspec m2 ssd. I'm curious how good or bad these will be. Vendors for these are kingspec for ssd and jinnyman for panel. Both are scheduled for some time in April 2021.
Will also attempt ax200 transplant with 2.36 BIOS when these arrive. That arrived after 5 months because USPS lost it.
Egregious overbidder
T440s won't turn on
by hedron » Sun Mar 31, 2024 10:31 pm » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 248 Views
Last post by hedron
Mon Apr 01, 2024 3:26 am
ThinkPad T470P Upgrades
by ThinkPad560X » Sat Mar 16, 2024 1:09 am » in ThinkPad T430-T490 / T530-T590 Series - 5 Replies
- 497 Views
Last post by ThinkPad560X
Sun Mar 24, 2024 4:44 pm
Users browsing this forum: pawelfriday and 5 guests
