T430 and 4G LTE
T430 and 4G LTE
Hello everyone
I'm interested in buying a T430 but I'm not 100% sure it can offer what I need, and by that I mean:
4G LTE support (*MUST*)
Dual band AC 867 mbps WiFi support (optional but very preferred)
Does the T430 support the above? How about the X230?
Thank you.
Thank you.
Re: T430 and 4G LTE
A warm welcome to our ThinkPad forum!
The T430/X230 series was launched in 2012.
The T430 had:
WiFi that connects via 802.11a/b/g/n and connects to networks of 2.4 GHz broadband as well as of 5 GHz broadband.
www.notebookcheck.net/Review-Lenovo-Thi ... 802.0.html
~3G Mobile Broadband Option
http://support.lenovo.com/sg/en/solutions/pd024213
***Note: The LCD unit must have the mobile broadband antenna built-in, otherwise no mobile broadband signal due to no antenna. Therefore you should buy only T430/X230 that came native with mobile broadband. ie: Do not try to add in your own mobile broadband card by yourself, as LCD may have no antenna.
~Honestly, I've used mobile broadband for 10+ years on my T42/T410/X1C3/X1C4 now, and for field office work (check emails, browse internet for info),
a 3G mobile broadband is plenty fast enough!
IF you are really set for 4G Mobile Broadband, think you need to get anything that is 2015 and onwards.
ie: 4G Mobile Boradband card came out during the 2015 era, for T450/X250 and perhaps X1 Generation 3, pls check with your region's ThinkPad specs.
Have fun deciding!
The T430 had:
Have fun deciding!
Re: T430 and 4G LTE
Correct me if i'm wrong, but you can only use whitelisted cards, so no 4G modem for t430.
You have two options: replacing original BIOS white Coreboot, which gets rid of whitelist or changing usb ID to the whitelisted one. Other than that you can use any mini pci-e 4G card. I use Sierra Wireless EM7345 in my t470s and after changing its usb ID it's working without problems.
Re: T430 and 4G LTE
@w0qj
Thank you for the warm welcome!
I have 1Gbps internet at home for more than 3 years now, so browsing the web with my 3G connection on the go felt like dial-up every time. Recently I got a new data plan which includes 100mbps+ speeds and hundreds of GB traffic so I really want to make use of it. For a good while now public wi-fi speeds are waay slower than cellular around here, that's why an AC card is not really a must. I almost never use wi-fi on my phone unless I am home.
@morali
So it is possible? How complicated was it? Is it easier to change the card's ID or flash coreboot?
The main reason I'm considering the T430 is the classic keyboard mod but the 4G LTE support is absolutely essential.
@morali
Re: T430 and 4G LTE
It is easier to change ID.
I recommend buying used Sierra Wireless 4G modem.
Here's blog which helped me with getting my modem to work: https://zukota.com/sierra-wireless-em74 ... vo-laptop/
You will find there useful topics about working with Sierra modems.
I had to install windows, so i took me little longer. Also pin password for modem was changed from "A170" and i couldn't use AT commands to change ID, as instructed on this blog. Your laptop won't boot with modem connected, you need another computer to change ID, without whitelist or hotpluging it to your thinkpad as I did, after booting Windows (it could be dangerous and destroy your motherboard, so be careful).
When you buy modem and password "A170" won't work, there's a script somewhere on zukota site, which can change usb ID without using AT commands.
goodluck!
goodluck!
WWAN 4g / LTE card for T420
by koden » Fri Dec 22, 2023 8:24 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 0 Replies
- 1181 Views
Last post by koden
T430 Thinklight and Integrated Camera not working
by wurmhol3 » Tue Oct 24, 2023 10:58 am » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 2560 Views
Fri Oct 27, 2023 7:12 am
- 1 Replies
- 225 Views
Last post by jronald
Mon Mar 11, 2024 9:37 am
T430 eGPU problems (windows)
by Blackbeak2 » Sat Nov 04, 2023 6:43 am » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 1994 Views
Last post by SAIYAN48
Sat Nov 04, 2023 1:33 pm
Users browsing this forum: No registered users and 90 guests
