T450 Linux (Fedora 25)
Suddenly my battery has stopped charging... well both of them... the BAT0 (Internal) reaches 60% and the external BAT1 (72Wh) reaches 40% or thereabouts.
Sometimes one is 62% and the other is 38% (seems to both balance around 100%).
Also doesn't show charging - but if I reboot it shows charging but charges to 60%/40%
This happens even with a FRESH copy of Linux (the old one deleted) as I reinstalled just in case.
Very puzzling?????
I don't run any battery management software but I used to run TLP which I think (forgot now I erased) I set battery levels similar to this for charging.
But even changing tlp (power management software in Linux) I still can't get above 60% for internal and 40% for external (or thereabouts)
Battery issue - help appreciated!
2020: P50/E3-1535M/24GB/3xSSD/FHD
2018: T550/16/IPS 3K/72Wh
2007-2018: T450, T520/i7, X200s, T500, A31p, A30p, T42p, X60s, X32, X31
Gone but not forgotten 1998-2006: 2006 T43p 2668-H2G (2GB/60), T22 2648-8EG (128/20) 2005 X40, X31 2004 T30 SXGA+, 600X, 2003 770 P233+DVD Card, 760XD 1998 760XL+104MB
Re: Battery issue - help appreciated!
Ok now seems to work.
Not sure why?
I did push the reset pin on the underside on the motherboard through the little hole. Not sure though whether that helped!
Very strange battery problem hope doesn't re-occur.
Not sure why?
- 4 Replies
- 3975 Views
Tue Dec 19, 2023 12:59 am
HELP! My X230 decided not to charge my non-genuine battery.
by canonmasta » Fri Dec 08, 2023 5:31 pm » in ThinkPad X230-X280 / X390 Series - 1 Replies
- 10793 Views
Sat Dec 09, 2023 12:07 am
T480: What kind of battery life can I expect with a WQHD display + 96Wh of battery?
by Maverick000 » Thu Oct 19, 2023 9:12 am » in ThinkPad T430-T490 / T530-T590 Series - 4 Replies
- 4495 Views
Last post by theterminator93
Tue Mar 05, 2024 10:27 pm
T42 Charges and works with the battery in but without battery will not power on.
by kale87 » Fri Oct 27, 2023 3:39 pm » in ThinkPad T40/T41/T42/T43 Series - 0 Replies
- 3154 Views
Last post by kale87
