Hi, everyone,
Maybe my question is just scratched from ignorance. I've been using my TP 460 (Win 10) everyday just to study (Word, EndNote, Chrome... that stuff.) Battery usually gave me 6 to 7 fantastic hours of fine work. However, just a couple of days ago, the battery icon in the taskbar has gone: nor hidden, nor shaded---just gone.
When looking at "Select which icons appear on the taskbar", in Settings, "Power" is on. When looking at "Turn system icons on or off", the "Power" button appears shaded, with no possibility of turning it on or off (even though it appears as "On").
I tried to clear all static from PC. So I removed the power cord and the battery, and prepared to push the power button several times, you know... But to my surprise, the computer started... and kept working for almost two hours! I don't get it: no battery, no power cord!
I waited until the power got drained. I put on the battery again, and it appears that the battery is charged up to 66 % So weird! And the icon is still missing.
What is happening? Any ideas, please? Should I press the reset pin after this?
Best regards,
Details:
-TP 460
-Bought as: new
-Date of purchase: June 2017
-Battery scheme: Balanced
-Last BIOS update: a couple of weeks ago
TP 460 weird battery behavior
Enrique
TP 460, Intel i7-6500U, 2.50 GHz, RAM 8Gb, HDD 1 Tb
BIOS: R06ET58W (1.32)
Windows 10 Pro (build: 15063)
Re: TP 460 weird battery behavior
The T460 has an INTERNAL and an EXTERNAL battery.
You need to fully switch off the laptop, then open it up and also remove the internal battery, before the hardware reset (holding the power button down for 15-20 seconds) works.
Also check this: https://forums.lenovo.com/t5/ThinkPad-T ... -p/3317965
Thank you very much, RealBlackStuff. Wow, I'm embarrassed! I didn't know that! Thanks for the useful link to another thread.
And how can I know which battery discharges in first place? Can this feature be related to the fact that the power icon dissappears from time to time? (Because, just for the record, now that I shut down the equipment and turned it on again, the icon has returned.)
Regards,
Regards,
Enrique
If you want to shut it pff without taling it apart, go into the BIOS and disable the internal battery. Then you can press the pwr button for 15 seconds.
- 1 Replies
- 8032 Views
Last post by robinadams
Fri Dec 15, 2023 12:05 pm
T480: What kind of battery life can I expect with a WQHD display + 96Wh of battery?
by Maverick000 » Thu Oct 19, 2023 9:12 am » in ThinkPad T430-T490 / T530-T590 Series - 4 Replies
- 4159 Views
Last post by theterminator93
Tue Mar 05, 2024 10:27 pm
T42 Charges and works with the battery in but without battery will not power on.
by kale87 » Fri Oct 27, 2023 3:39 pm » in ThinkPad T40/T41/T42/T43 Series - 0 Replies
- 2964 Views
Last post by kale87
ThinkPad A22m battery recondioning after battery rebuild
by kfzhu1229 » Mon Dec 11, 2023 5:57 pm » in ThinkPad R, A, G and Z Series - 0 Replies
- 2386 Views
