T440p RAM upgrade
T440p RAM upgrade
Hi everybody.
Just bought a second hand T440p and I am super happy.
I am planning to buy fill the empty slot of RAM with a 1x8GB (the other slot already hosts 4GB).
As I am not that expert, i am in doubt on the type of memory I should buy.
I saw the official specs at https://support.lenovo.com/it/en/solutions/pd100280 and I found this on ebay: https://www.ebay.it/itm/1x-8GB-PC3L-128 ... Sw5nxaYq-X.
it seems what I need, but the "for samsung" is confusing me... The specs seems right to me, do you have any thought?
Sorry to ask such a basic question, but I am not a fan of buying online, especially when it's from that far from my house and I don't know exactly what I am buying
Re: T440p RAM upgrade
It's not going to be limited to just Samsung notebooks. Maybe that's a typo or something. It matches your specs and I'm pretty sure one of my own machines has exactly that RAM installed too.
| 701c | X220 | T420 | X230 | T430s | W540
This is samsung OEM memory good for any notebooks also, You can also choose to get one made by Micron, Crucial, Hynix as well.
Why not go matched set of two 8GB modules not just one to your 4GB so you can preserve the dual channel mode which is very helpful for *both* integrated GPU and CPU. 4GB and 8GB will not enable dual mode.
Cheers, thinkpadcollection
Thanks. Wow, didn't know I can't dual mode with two different slots... already bought one 8gb because of my limited budget. Does this mean I cannot get much increase having 12gb RAM or only dual mode (which I guess would lead to the question "what is dual mode exactly?")
Also, do the two slots need to be exatlctly the same (e.g. two from samsung same as the one I bought) or it's only a matter og matching the GB? I guess the former, but I might be wrong.
Dual mode is not that important. I doubt in normal usage you'll ever notice dual mode. I've mix and match memory size and chip all the time. 95% of the time there's no issue at all. If your budget is tight, 1 additional memory will not be a problem. Others will tell you that unless you buy brand X, on the 3rd hour, 18 minutes, 43 seconds of a second blue moon during the alignment of Mars and Venus relative to Pluto that the world will end.
Ok thanks for clarifying.
For the sake of (my) knowledge, RAM in dual channel mode can be activated only if the following requirements are met:
- Same memory size (e.g. 1GB + 1GB)
- Same DIMM configuration in both channels
- Same configuration in symmetric memory slots
- Same brand RAM (which asnwers my question)
- Same tech charachteristics
- Same speed (MHz)
May work with different OEM names of different memory modules even they are same memory capacity could have different timings but test well. And measure graphics performance with one, two matched and two different capacity like 4GB and 8GB and you will see different numbers on performance for graphics especially on integrated GPU built into CPU.
Also mixing different OEM names may have memory chips on each modules are different timings requirements.
This comes from my 29 years of computing and I find working with matched in both OEM brand and model number memory in a pair or in quad modules (for computers which have 4 memory slots) offers much better reliable computing and does not corrupt data (important!). And I do see difference in windows even play back and smoother scrolling not just for heavy graphics.
FS: ThinkPad T440p
by PiZzA EnGiNeEr » Tue Oct 31, 2023 3:43 pm » in Marketplace - Forum Members only - 2 Replies
- 1888 Views
Last post by PiZzA EnGiNeEr
Sat Nov 04, 2023 2:52 pm
T440p + Ultra Dock, but dock video out (HDMI) not working
by Arf the Lab » Sat Nov 04, 2023 6:58 pm » in ThinkPad T430-T490 / T530-T590 Series - 6 Replies
- 5087 Views
Mon Nov 06, 2023 1:39 am
thinkpad t440p Linux trackpad + trackpoint not working.
by jaggreaney » Thu Nov 09, 2023 2:54 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 2795 Views
Thu Nov 09, 2023 11:48 pm
Unconnected black wire on fan T440P
by euless » Thu Nov 23, 2023 6:22 am » in ThinkPad T430-T490 / T530-T590 Series - 6 Replies
- 2062 Views
Last post by euless
Fri Nov 24, 2023 1:48 pm
