T530 vs T550?
marlinspike
T530 vs T550?
#1 Post by marlinspike » Sat May 19, 2018 8:17 pm
For a non-power user, which would be better in terms of things like reliability, repairability, compatibility (esp with Win 10), low temps and good battery life? And how big are the differences in these categories?
T60 2007-7JU (15" Flexview, has a T60p mobo for the v5200, 4gb ram, changed HDD w/7200rpm 100gb, T7400 2.16ghz Core 2 Duo)
X201
elray
Re: T530 vs T550?
#2 Post by elray » Sun May 20, 2018 2:10 pm
The T550 crams a non-optional numeric pad into the same space the the T530 used to plant a non-optional chiclet keyboard.
The latter I can tolerate. The keypad, however, placed by some nameless, faceless, committee of cupertino-worshipping corporate
"design" nimrods, is truly the last straw.
Good thing I like small screens.
X200s, Vista Business 64
Moderator
Moderator
Re: T530 vs T550?
#3 Post by dr_st » Sun May 20, 2018 2:24 pm
Cupertino-worshipping?
Uhm... have you ever seen a single Macbook with a numeric keypad?
At least try to make some sense in your rants, people. :wink: The numeric keypad has its uses and advantages. The 6-row keyboard has no advantages.
Thinkpad 25 (20K7), X1 Carbon (20HQ), Yoga 14 (20FY), T430s (IPS FHD + Classic Keyboard), X220 4291-4BG, X61 7673-V2V
T60 2007-QPG, T42 2373-F7G, X32 (IPS Screen), A31p w/ Ultrabay Numpad, A21m 2628-GXU
marlinspike
Re: T530 vs T550?
#4 Post by marlinspike » Sun May 20, 2018 4:31 pm
It looks like the keys are the same size as the T530's, they just made room for the numpad by moving the speakers to the bottom right? And while normally speakers at the bottom are the worst, it seems from reviews like in this instance they actually got louder?
It is a shame they're all chiclet keyboards now, but unless you want to go back to pre-Win 10 compatible computers, you have no choice.
X201
Tasurinchi
Re: T530 vs T550?
#5 Post by Tasurinchi » Wed May 23, 2018 2:35 am
+1 for the T550, it has a more modern architecture, options to 3K screens and can take max 2x 16GB RAM vs 2x 8GB RAM of the T530. Though the latter has the advantage that you can mod the BIOS and install a 7-row keyboard from the xx20 generation.
zephxiii
Re: T530 vs T550?
#6 Post by zephxiii » Wed May 30, 2018 9:28 am
T530 is a good ol machine but T550 would be nicer. I have found the T440/T550+ easier to work on as well (taking it apart).
