T520 battery in T530
I have an old but very good shape T520 battery. These physically "fit" but it does not mean they work
Is there any reason these are not working other than sales?
(stable under reduction)
Re: T520 battery in T530
The *30 series introduced new batteries with special chip to enable fast-charging. The *30 firmware will not charge a *20 battery (although it will run off it).
The same EC mod that allows a classic keyboard to be used can also be utilized to disable this check, and allow *20 batteries to be charged.
Ok, this brings the light.
I guess performing the controller mod just for the battery would not work properly unless the classic keyboard is used as well?
Nope, you can do just the battery-mod with EC for all xx30 Thinkpads.
I have it on a self-booting USB-stick, so I don't need to install Linux first.
My current X230 has that EC battery-mod (and an X220 batt.), but is otherwise standard.
Great, thanks. This spares me lots of time
EDIT: other than that: T530 battery is backwars-compatible with no mod needed I presume?
Correct.
Abused daily: T520, X200s
Hate to say, but can't source the code...
May I ask users who done this to upload the modded files and share them? I'm only looking to enable the battery.
Download the .ZIP from: https://github.com/hamishcoleman/thinkpad-ec and read the Readme under it.
After unzipping it on your drive, you'll find some sub-dirs with xxx.xxx.img.d
In the matching sub-dir, check the last file-extensions.
If you want ONLY to remove the EC battery-check, you must add .OFF to files 001 - 005 and remove .OFF from 006.
Now go do your Linux stuff.
Unfortunately I don't see T530 in that group, unless you can also use either T430 or W530.
Ask forum-member hamish.
For people who just want the battery-check removed from ONLY the X230 (no other models!), go here: https://www.reddit.com/r/thinkpad/comme ... _batterys/
I have downloaded, checked and used the Google-file in the first post. It is OK, no malware. Ignore all the other dummies posting there.
Make your USB stick and off you go.
Like I said, this mod ONLY applies to regular X230, nothing else!
Possible bad reads from T530 using pico
by ame » Sat Nov 11, 2023 10:15 pm » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 1907 Views
Last post by ame
Windows 11 on Thinkpad T530?
by trylgsk » Wed Feb 07, 2024 3:56 am » in ThinkPad T430-T490 / T530-T590 Series - 11 Replies
- 1029 Views
Thu Mar 21, 2024 5:33 pm
ThinkPad T530 Very little power, Will not power on
by ThinkPad560X » Sun Mar 10, 2024 12:42 am » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 209 Views
Last post by ThinkPad560X
Sun Mar 10, 2024 12:57 pm
T520 Power Management Question
by Callahan » Wed Oct 11, 2023 7:29 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 4 Replies
- 5319 Views
Last post by Callahan
Thu Oct 12, 2023 6:10 pm
Users browsing this forum: No registered users and 59 guests
