I'm trying to install Linux Mint on my T530 that already has Win7 installed.
When installing Linux Mint though, it's not finding the Win7 partition:
Any tips to make it see the Win7 partition?
In bios I have "UEFI/Legacy Boot" set to "Both". Then "UEFI/Legacy Boot Priority" is set to "Legacy First", and "CSM Support" is set to "yes".
If I set it to "Legacy Only" Windows won't boot, it goes to the Boot Menu, and selecting "Windows Boot Manager" does nothing.
Any tips?
According to this guide I should disable "secure boot" and "fast boot" in bios. I found secure boot and it was already disabled, but don't see an option for fast boot:
https://www.tecmint.com/install-linux-m ... uefi-mode/
Is it important for the Mint installer to see the Windows partition? It's been awhile since I installed it, but I'm pretty sure in the past it was seeing the Windows partition.
Using latest Mint (19.3).
I have the drive imaged so can take my chances by clicking through the dialog, but wondering if anyone has any words of wisdom.
Edit: I found this tutorial for converting GPT partition table (UEFI bios) to MBR (legacy bios):
https://www.youtube.com/watch?v=OP7NikNiCuk
It uses EaseUS Partition Manager, but it's $60 and the free and trial versions won't do it.
Issue installing Linux Mint after Windows 7 (solved)
Re: Issue installing Linux Mint after Windows 7 (dual boot)
Aha, solved it. I set "UEFI/Legacy" to "UEFI" and the Mint installer was able to find the Windows partition.
That's because Windows was installed in UEFI mode. I guess all OS's have to be in the same mode, either UEFI or Legacy.
And because I had it set to "both" with "legacy first" Mint was booting into Legacy mode, and therefore not finding the Windows partition.
Working great now.
Working great now.
updating T480 bios without Windows (I use Linux)
by redglow » Fri Nov 03, 2023 3:15 am » in ThinkPad T430-T490 / T530-T590 Series - 25 Replies
- 30450 Views
Last post by redglow
Tue Nov 14, 2023 1:00 pm
[FA][UK & global] Mint 380E from S/390 mainframe
by ThinkDan » Thu Jan 18, 2024 7:23 pm » in Marketplace - Forum Members only - 1 Replies
- 1030 Views
Last post by ThinkDan
Fri Feb 02, 2024 4:20 am
- 3 Replies
- 1022 Views
Last post by BillMorrow
Tue Mar 19, 2024 1:25 pm
[FA][UK & Global] Mint, boxed ThinkPad 365XD with original preload [WARNING: PICS]
by ThinkDan » Sun Mar 31, 2024 6:11 pm » in Marketplace - Forum Members only - 1 Replies
- 412 Views
Last post by solidpro
Mon Apr 01, 2024 3:42 am
