Pre Installed OS License in T460 BIOS
I have a T460 with Windows 10 Pro installed. I can see the preinstalled OS license in the BIOS as SDK0XXXXXX (X added in place of actual numbers). But this doesn't correspond to the activation code a get with any of the key extraction utilities (XXXXX-XXXXX-XXXXX-XXXXX). Is there any way to extract the preinstalled OS license key from this 10 key code or is the extraction utility actually doing this for me?
Thanks in advance,
Thanks in advance,
Keith
(Formerly 600E, T21, T30, T40, T41, 2xT42, 2xT61p, T420, 2x Ideapad K1)
(Currently 4xT430, 2xT460, H520S, M910q, M920q, M70q)
Re: Pre Installed OS License in T460 BIOS
I created a script at work a few years ago for us to use when we imaged systems needing reactivation with the BIOS embedded license key.
Paste this into a text file, then rename it with a .bat or .cmd extension. Right click then run it as administrator.
If all you want to do is see the key, run this from an elevated Command Prompt.
@echo off
cls
for /f "skip=1 tokens=*" %%a in ('wmic path softwarelicensingservice get OA3xOriginalProductKey') do (
if not defined second_line set "second_line=%%a"
echo Activating Windows with product key %second_line% found in BIOS...
slmgr.vbs /ipk %second_line%
slmgr.vbs /ato
pause
T420 IPS FHD | X220 IPS FHD | T61p·T61·43·42p|X13 Yoga G3·220T·301·41T·24·23·22|G41|A31p·22m|i1200|TransNote
Thanks terminator. I tried running the script from the administrator command prompt:
but got an invalid argument error. Did I understand this correctly?
Keith
No, that sounds right. I just ran it on my T25 and it worked, so I'm not sure what might be going on.
C:\WINDOWS\system32>wmic path softwarelicensingservice get OA3xOriginalProductKey
XXXXX-XXXXX-XXXXX-XXXXX-V8RC2
OK, I found a VBS script on the internet and it looks like the key that windows is activated with is the same one that is hard coded into the BIOS.
Keith
ThinkPad T460 refuses to stay on after power button is pressed
by Fropple! » Fri Dec 08, 2023 1:31 am » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 7536 Views
Last post by Fropple!
Classic ThinkPads installed in IBM System/390 and zSeries mainframes
by ThinkDan » Mon Nov 27, 2023 4:39 pm » in ThinkPad Legacy Hardware - 13 Replies
- 4474 Views
Last post by ThinkDan
Fri Feb 02, 2024 4:18 am
updating T480 bios without Windows (I use Linux)
by redglow » Fri Nov 03, 2023 3:15 am » in ThinkPad T430-T490 / T530-T590 Series - 25 Replies
- 30509 Views
Last post by redglow
Tue Nov 14, 2023 1:00 pm
t430 bios keyboard illumination tab has vanished
by Ray73 » Wed Nov 29, 2023 6:53 pm » in ThinkPad T430-T490 / T530-T590 Series - 5 Replies
- 2851 Views
Last post by TPFanatic
Thu Nov 30, 2023 4:23 pm
Users browsing this forum: No registered users and 39 guests
