T470 backlight fuse
T470 backlight fuse
Stupidly tried the change the display on my T470 without removing the internal battery and now the fuse is blown and the back light doesn't power on. I can still see the Thinkpad logo faintly when I power it on though and it works with external displays no problem.
Does anyone know which fuse I should be taking a look at? I figure I should be able to just solder over it.
Re: T470 backlight fuse
Don't have any specific details on the T470, but traditionally the display fuse has been located next to connector where the ribbon cable from the lid attaches to the motherboard.
There is a fuse labelled F39 and a spot for a fuse labelled F44 where the cable from the display connects to the motherboard. The F39 gives me continuity, but the F44 seems completely absent.
Knock, knock.... you've got a PM!
I'm in exactly the same spot at the moment. Have a T470 and did the screen replacement without disconnecting internal battery.
The fuse configuration is also the same: the easily accessible side of the board shows fuses F39 (~ 0.5 Ohm) and F44 (absent) close to the video connector.
Was there a conclusion to this?
(Also I'm new on this forum, because it's the only place where I could find the lcd-backlight problem for the T470)
You need to look for backlight Fuse F3 (type ERBRD3R00X = 3A/32V/Fast) near the LCD-connector.
Fuses F39 and F44 are 0.5A/32V/Fast and are not for the backlight.
I finally had both the components and the time to attempt a fix. The silkscreen for the board is available in a badcaps.net-thread, which makes it easy to CTRL-F for the fuses.
I managed to remove the motherboard and check the fuses. In my case F3 was okay, but F7 was open/broken, like here. After carefully replacing it with a new fuse (ERBRD3R00X), the backlight works!
This was an exciting adventure, since I never took my laptop apart that far before or soldered components so small.
Thanks for the help!
Any Advance docks for ThinkPad T470?
by ThinkPad560X » Wed Feb 28, 2024 1:12 am » in Off-Topic Stuff - 4 Replies
- 587 Views
Wed Feb 28, 2024 3:21 am
ThinkPad T470 bios locked
by ThinkPad560X » Sat Mar 02, 2024 1:43 am » in ThinkPad T430-T490 / T530-T590 Series - 6 Replies
- 739 Views
Last post by ThinkPad560X
Sat Mar 02, 2024 1:58 pm
ThinkPad T470 motherboard swap
by ThinkPad560X » Tue Mar 19, 2024 12:57 am » in ThinkPad T430-T490 / T530-T590 Series - 10 Replies
- 797 Views
Wed Mar 20, 2024 9:39 pm
- 2204 Views
Last post by DavidGould
Tue Dec 12, 2023 4:17 pm
