I've purchased a T460s with a 250GB SSD M.2 SATA for a colleague in African. I would like to upgrade this laptop, if possible, to a larger hard drive. I know that I can replace the existing drive with a 500 GB SSD or a 1TB SSD M.2 SATA.
However, before going that route I'm wondering if there might be other options to consider? Would it be possible, for example, to add a secondary "drive" of some sort to this laptop?
Thanks for your advice!
-FRANK
T460s hard drive upgrade options
Re: T460s hard drive upgrade options
You can install a Samsung 950 PRO NVMe or one like this model also. There is not a extra space for a second drive though So I would get a larger drive for windows 10 like 512 +. There is on some models right side near the screen a sim slot for A micro SD card. Mine unit has this. When you upgrade any hardware disconnect the batteries ahead of time. And any SD cards installed.
Another T460s won't start
by johnmsch » Sat Dec 30, 2023 1:07 am » in ThinkPad T430-T490 / T530-T590 Series - 6 Replies
- 1981 Views
Last post by johnmsch
Thu Feb 01, 2024 7:47 pm
T460s - No 3.5mm jack audio output, but working speakers and jack detection
by Sanras » Mon Jan 29, 2024 1:50 pm » in ThinkPad T430-T490 / T530-T590 Series - 10 Replies
- 1285 Views
Sun Mar 24, 2024 1:57 am
Using the display and keyboard from a dead T460s?
by Gord K. » Sat Feb 10, 2024 12:10 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 368 Views
Sun Feb 11, 2024 6:32 am
T460s - Touchpad doubleclicks occasionally when clicking once
by Sanras » Sat Mar 23, 2024 5:19 pm » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 77 Views
Last post by Sanras
Users browsing this forum: No registered users and 44 guests
