T460s Bottom Panel Loosening?
My T460s bottom panel will not stay on in front. There's about a 1/16" space that opens at the front after all the screws are tight. It looks like the plastic clips at the front might be replaceable, but they don't appear damaged.
Anybody know anything about this?
Re: T460s Bottom Panel Loosening?
I am not sure, if I understand your problem correctly, but owing my experience with putting together many off leased ThinkPads, this panel needs to "click" a little. So you kind of push it forward and downwards.
Thanks. That sounds like what I have done. With comp upside down and oriented with touchpad closest to me, hang the bottom plate under the edge closest to me, then carefully push down all the way around and do the screws. By the time the screws are tight, the part of the bottom that was originally hung under the edge has popped up, leaving about a 1/16" gap there. It was not always that way, and I can't see anything broken. Something is not retaining the bottom plate on that edge.
SWOLLEN BATTERY! The battery nearest the front edge was swollen, making a fulcrum that had the back at about a 20 degree angle after the front bottom was snapped under the body. That put the back under tension and made that edge pop out. Removing the battery fixed it. Back slips on flat now, with no tension. First experience with swollen battery... Feels like a water balloon. Utilities said it was a good battery though...
Bring it to a recycling center before it sets your house on fire!
Can't waste it. I'll use it to blow out that old stump out back.
Another T460s won't start
by johnmsch » Sat Dec 30, 2023 1:07 am » in ThinkPad T430-T490 / T530-T590 Series - 6 Replies
- 2306 Views
Last post by johnmsch
Thu Feb 01, 2024 7:47 pm
T460s - No 3.5mm jack audio output, but working speakers and jack detection
by Sanras » Mon Jan 29, 2024 1:50 pm » in ThinkPad T430-T490 / T530-T590 Series - 10 Replies
- 1483 Views
Sun Mar 24, 2024 1:57 am
Using the display and keyboard from a dead T460s?
by Gord K. » Sat Feb 10, 2024 12:10 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 465 Views
Sun Feb 11, 2024 6:32 am
T460s - Touchpad doubleclicks occasionally when clicking once
by Sanras » Sat Mar 23, 2024 5:19 pm » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 200 Views
Last post by Sanras
