I've received a T450s laptop to refurbish. Everything on the laptop seems to work OK except that the TrackPoint is not working. At the same time the Trackpad IS working. Also a wired mouse plugged into the USB port is working fine.
In the "ThinkPad" tab of "Mouse Properties" the "Enable TrackPoint" section is greyed out so that I am unable to "Enable TrackPoint". In BIOS, however, the CONFIG tab indicates that TrackPoint is enabled.
I tried updating everything available using the Lenovo Systems Updater and Windows 10 updates. No change.
I tried uninstalling the Synaptics Pointing Device in the Device Manager and rebooting. No change
I have removed, cleaned and reinstalled the keyboard taking care to make sure that the keyboard ribbons are fully installed and clicked into place. I hate removing the keyboard on this model!
Does this sound like the problem is a bad keyboard? Or, is there another setting that I am missing that can enable the TrackPoint?
Thanks for any advice and you can provide.
UPDATE: I JUST FOUND AN SPARE KEYBOARD AND USED IT TO REPLACE THE ONE WHERE THE TRACKPOINT WAS NOT WORKING. THAT FIXED THE PROBLEM. SO, THIS WAS A HARDWARE (KEYBOARD) PROBLEM AND NOT A SOFTWARE ISSUE.
FRANK
SOLVED: T450s TrackPoint not working but TrackPad is working
thinkpad t440p Linux trackpad + trackpoint not working.
by jaggreaney » Thu Nov 09, 2023 2:54 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 2402 Views
Thu Nov 09, 2023 11:48 pm
X230 trackpoint, mouse buttons and some keys still not working after keyboard change
by frog4 » Mon Jan 22, 2024 4:24 pm » in ThinkPad X230-X280 / X390 Series - 2 Replies
- 1229 Views
Last post by frog4
Tue Jan 23, 2024 5:22 am
T440p + Ultra Dock, but dock video out (HDMI) not working
by Arf the Lab » Sat Nov 04, 2023 6:58 pm » in ThinkPad T430-T490 / T530-T590 Series - 6 Replies
- 4632 Views
Mon Nov 06, 2023 1:39 am
Windows 11 detects wrong TrackPad model (because i've installed the wrong one ;) )
by Quardah » Sun Oct 08, 2023 10:00 pm » in ThinkPad T430-T490 / T530-T590 Series - 3 Replies
- 5755 Views
Wed Oct 11, 2023 12:18 am
Users browsing this forum: No registered users and 60 guests
